-N
- once the authentication is complete, the ssh
program executes in the background, meaning the prompt should be returned so that the telnet
command can be entered.
-f
-L
- the local/forwarding port number, for this example, 23000
- the local loopback address, 127.0.0.1:23. Port 23 is reserved for
ssh
- The IP address of the EAGLE IPSM. For this example, 10:253.104.36.
For this example, enter this command.
ssh -N -f -L 23000:127.0.0.1:23 10:253.104.36
- When issuing the
ssh
command, if the IPSM on the EAGLE has undergone a hard reset, the ssh
key stored in the local_host
file must be purged.
- If you are making the connection to the EAGLE for the first time, and you are prompted to accept the
ssh
key, accept the ssh
key and proceed to 4
