| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to enable and turn on the 15 Minute Measurements controlled feature, using the feature’s part number and a feature access key. This feature allows EAGLE measurements to be collected every 15 minutes.
To enable and turn on the 15 Minute Measurements controlled feature, the following requirements must be met:
The enable-ctrl-feat, ent-serial-num, and chg-ctrl-feat commands are used to enable and turn on the 15 Minute Measurements controlled feature using the feature’s part number and a feature access key.
The feature access key for the 15 Minute Measurements controlled feature is based on the feature’s part number and the serial number of the EAGLE, making the feature access key site-specific.
The enable-ctrl-feat command enables the feature by inputting the feature’s access key and the feature’s part number with these parameters:
:fak – The feature access key provided by Oracle. The feature access key contains 13 alphanumeric characters and is not case sensitive.
:partnum – The Oracle-issued part number of the 15 Minute Measurements controlled feature, 893012101.
The enable-ctrl-feat command requires that the database contain a valid serial number for the EAGLE, and that this serial number is locked. This can be verified with the rtrv-serial-num command. The EAGLE is shipped with a serial number in the database, but the serial number is not locked. The serial number can be changed, if necessary, and locked once the EAGLE is on-site, with the ent-serial-num command. The ent-serial-num command uses these parameters.
:serial – The serial number assigned to the EAGLE. The serial number is not case sensitive.
:lock – Specifies whether or not the serial number is locked. This parameter has only one value, yes, which locks the serial number. Once the serial number is locked, it cannot be changed.
To enter and lock the EAGLE’s serial number, theent-serial-num command must be entered twice, once to add the correct serial number to the database with the serial parameter, then again with the serial and the lock=yes parameters to lock the serial number. You should verify that the serial number in the database is correct before locking the serial number. The serial number can be found on a label affixed to the control shelf (shelf 1100).This feature cannot be temporarily enabled (with the temporary feature access key).
Once this feature has been enabled, the feature must be turned on with the chg-ctrl-feat command. The chg-ctrl-feat command uses these parameters:
:partnum – The Oracle-issued part number of the 15 Minute Measurements controlled feature, 893027701.
:status=on – used to turn the 15 Minute Measurements controlled feature on.
Once the 15 Minute Measurements controlled feature has been turned on, it be cannot be turned off.
The status of the features in the EAGLE is shown with the rtrv-ctrl-feat command.
After the 15 Minute Measurements controlled feature is enabled and turned on, the 15 minute measurement collection option in the measurement options table must be turned on.
Figure A-3 Activating the 15 Minute Measurements Controlled Feature
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
