| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to change the IMT bus alarm thresholds using the chg-th-alm command and these parameters.
:imtbusutllvl1 – The percentage for the IMT bus combined utilization level 1 threshold alarm (reported on the IMT system). The percentage for the IMT bus combined utilization level 1 threshold alarm, from 35 to 70 and is shown in the IMT Bus Combined Utilization Alarm Level 1 field of the rtrv-th-alm output. The system default value is 70. When this threshold is exceeded, UAM 0027 is generated.
:imtbusutllvl2 – The percentage for the IMT bus combined utilization level 2 threshold alarm (reported on the IMT system). The percentage for the IMT bus combined utilization level 2 threshold alarm, from 40 to 80 and is shown in the IMT Bus Combined Utilization Alarm Level 2 field of the rtrv-th-alm output. The system default value is 80. When this threshold is exceeded, UAM 0028 is generated.
After the chg-th-alm command is performed, the imtbusutllvl2 parameter value must be greater than the imtbusutllvl1 parameter value.
:imtcongestlvl1 – The percentage for the IMT bus congestion level 1 threshold alarm (reported on the HIPR2 card). The percentage for the IMT bus congestion level 1 threshold alarm, from 35 to 70 and is shown in the IMT Bus Congestion Alarm Level 1 field of the rtrv-th-alm output. The system default value is 70. When this threshold is exceeded, UAM 0030 is generated.
:imtcongestlvl2 – The percentage for the IMT bus congestion level 2 threshold alarm (reported on the HIPR2 card). The percentage for the IMT bus congestion level 2 threshold alarm, from 40 to 80 and is shown in the IMT Bus Congestion Alarm Level 2 field of the rtrv-th-alm output. The system default value is 80. When this threshold is exceeded, UAM 0031 is generated.
After the chg-th-alm command is performed, the imtcongestlvl2 parameter value must be greater than the imtcongestlvl1 parameter value.
For more information on these alarms, refer to Unsolicited Alarm and Information Messages Reference.
The chg-th-alm command contains other optional parameters. These parameters are not shown here because they are not necessary to configure the IMT bus alarm thresholds. These parameters are explained in more detail in Commands User's Guide.
Figure 4-33 Configuring the IMT Bus Alarm Thresholds
