| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to change an existing entry in the frame power alarm threshold table. The frame entry in the power alarm threshold table is changed using the chg-frm-pwr command with these parameters:
:frm – The name of the frame being added to the power alarm threshold table, cf00, ef00, ef01, ef02, ef03, or ef04.
:thrshld – The power threshold value, from 30 to 65 amps.
The frame power alarm threshold table defines the power level threshold, in amps, for each frame in the EAGLE. The power level threshold determines when alarms regarding the amount power used by the frame are generated. Three alarms can be generated for the power levels.
More information on these alarms is shown in Unsolicited Alarm and Information Messages Reference.
When setting the threshold value (the thrshld parameter value), the threshold value should be greater than the amount of power being used by the frame. The power being used by the frame is displayed in the Power Consumption (Amps) column in the rtrv-stp output. The threshold value should also be high enough to avoid generating any alarms.
Table 4-7 shows selected threshold values and the power levels for a frame that would generate a minor alarm for that threshold value.
Table 4-7 Power Level to Generate a Minor Alarm
| Threshold Value | Power Level to Generate a Minor Alarm |
| 30 |
27 |
| 35 |
31.5 |
| 40 |
36 |
| 45 |
40.5 |
| 50 |
45 |
| 55 |
49.5 |
| 60 |
54 |
| 65 |
58.5 |
Figure 4-32 Changing an Entry in the Frame Power Alarm Threshold Table
