| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This section presents the procedure for restoring system data from a system backup removable media that was made by performing Backing Up System Data to the Removable Media.
Caution:
Using theaction=restore parameter with the chg-db command is an emergency recovery procedure, and requires the init-sys command to download the restored database to all the cards in the EAGLE.Caution:
If the restore device state option is on, shown by theON value for the RSTRDEV field in the rtrv-stpopts command output, the state of the cards, SS7 signaling links, TCP/IP data links, and terminals before the chg-db:action=restore and init-sys commands are performed will not be maintained after these commands are performed. The persistent device state table becomes obsolete and is disabled. UIM 1257 is generated.rlghncxa03w 09-10-01 16:07:48 GMT EAGLE5 41.1.0 1234.1257 SYSTEM INFO DB Restore has cleared and disabled PDS
copy-gpl command. Perform the following substep.copy-gpl:sloc=1115:dloc=1114:sdrv=remove
During command execution, these messages should appear.
rlghncxa03w 09-10-01 14:50:46 GMT EAGLE5 41.1.0
COPY-GPL: MASP A - COPY STARTS ON REMOVABLE DRIVE
COPY GPL: MASP A - COPY TO STANDBY MASP COMPLETE
rtrv-gpl command. This is an example of the possible output:
rlghncxa03w 8-12-13 07:01:08 GMT EAGLE5 45.0.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SIPHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SIPHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 SIPHC 1115 ----------- ----------- ----------- ----------- GLS 1114 134-003-000 134-003-000 134-002-000 134-003-000 GLS 1116 134-003-000 134-002-000 134-002-000 134-003-000 GLS 1115 ----------- ----------- ----------- ----------- CDU 1114 163-001-000 163-001-000 163-000-000 163-001-000 CDU 1116 163-001-000 163-000-000 163-000-000 163-001-000 CDU 1115 ----------- ----------- ----------- ----------- IMT 1114 134-003-000 134-003-000 134-002-000 134-003-000 IMT 1116 134-003-000 134-002-000 134-002-000 134-003-000 IMT 1115 ----------- ----------- ----------- ----------- ATMANSI 1114 134-003-000 134-003-000 134-002-000 134-003-000 ATMANSI 1116 134-003-000 134-002-000 134-002-000 134-003-000 ATMANSI 1115 ----------- ----------- ----------- ----------- BPHCAP 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPHCAP 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPHCAP 1115 ----------- ----------- ----------- ----------- BPDCM 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPDCM 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPDCM 1115 ----------- ----------- ----------- ----------- BLMCAP 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLMCAP 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLMCAP 1115 ----------- ----------- ----------- ----------- OAMHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 OAMHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 OAMHC 1115 ----------- ----------- ----------- ----------- HIPR2 1114 134-003-000 134-003-000 134-002-000 134-003-000 HIPR2 1116 134-003-000 134-002-000 134-002-000 134-003-000 HIPR2 1115 ----------- ----------- ----------- ----------- VXWSLAN 1114 134-003-000 134-003-000 134-002-000 134-003-000 VXWSLAN 1116 134-003-000 134-002-000 134-002-000 134-003-000 VXWSLAN 1115 ----------- ----------- ----------- ----------- IPLIM 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPLIM 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPLIM 1115 ----------- ----------- ----------- ----------- IPLIMI 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPLIMI 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPLIMI 1115 ----------- ----------- ----------- ----------- SS7IPGW 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7IPGW 1116 134-003-000 134-002-000 134-002-000 134-003-000 SS7IPGW 1115 ----------- ----------- ----------- ----------- VSCCP 1114 134-003-000 134-003-000 134-002-000 134-003-000 VSCCP 1116 134-003-000 134-002-000 134-002-000 134-003-000 VSCCP 1115 ----------- ----------- ----------- ----------- ATMITU 1114 134-003-000 134-003-000 134-002-000 134-003-000 ATMITU 1116 134-003-000 134-002-000 134-002-000 134-003-000 ATMITU 1115 ----------- ----------- ----------- ----------- VCDU 1114 163-001-000 163-001-000 163-000-000 163-001-000 VCDU 1116 163-001-000 163-000-000 163-000-000 163-001-000 VCDU 1115 ----------- ----------- ----------- ----------- BPMPL 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPMPL 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPMPL 1115 ----------- ----------- ----------- ----------- SS7ML 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7ML 1116 134-003-000 134-002-000 134-002-000 134-003-000 SS7ML 1115 ----------- ----------- ----------- ----------- BPHMUX 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPHMUX 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPHMUX 1115 ----------- ----------- ----------- ----------- IPGWI 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPGWI 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPGWI 1115 ----------- ----------- ----------- ----------- IPS 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPS 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPS 1115 ----------- ----------- ----------- ----------- BPDCM2 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPDCM2 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPDCM2 1115 ----------- ----------- ----------- ----------- EROUTE 1114 134-003-000 134-003-000 134-002-000 134-003-000 EROUTE 1116 134-003-000 134-002-000 134-002-000 134-003-000 EROUTE 1115 ----------- ---------- ----------- ----------- BPMPLT 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPMPLT 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPMPLT 1115 ----------- ----------- ----------- ----------- MCP 1114 134-003-000 134-003-000 134-002-000 134-003-000 MCP 1116 134-003-000 134-002-000 134-002-000 134-003-000 MCP 1115 ----------- ----------- ----------- ----------- BPHCAPT 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPHCAPT 1116 134-003-000 134-002-000 134-002-000 134-003-000 BPHCAPT 1115 ----------- ----------- ----------- ----------- SS7HC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7HC 1116 134-003-000 134-002-000 134-002-000 134-003-000 SS7HC 1115 ----------- ----------- ----------- ----------- BLBIOS 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLBIOS 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLBIOS 1115 ----------- ----------- ----------- ----------- BLCPLD 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLCPLD 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLCPLD 1115 ----------- ----------- ----------- ----------- GLSHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 GLSHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 GLSHC 1115 ----------- ----------- ----------- ----------- IMTPCI 1114 134-003-000 134-003-000 134-002-000 134-003-000 IMTPCI 1116 134-003-000 134-002-000 134-002-000 134-003-000 IMTPCI 1115 ----------- ----------- ----------- ----------- PLDPMC1 1114 134-003-000 134-003-000 134-002-000 134-003-000 PLDPMC1 1116 134-003-000 134-002-000 134-002-000 134-003-000 PLDPMC1 1115 ----------- ----------- ----------- ----------- IPLHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPLHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPLHC 1115 ----------- ----------- ----------- ----------- IPGHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPGHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPGHC 1115 ----------- ----------- ----------- ----------- SS7EPM 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7EPM 1116 134-003-000 134-002-000 134-002-000 134-003-000 SS7EPM 1115 ----------- ----------- ----------- ----------- BLBEPM 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLBEPM 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLBEPM 1115 ----------- ----------- ----------- ----------- BLVXW6 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLVXW6 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLVXW6 1115 ----------- ----------- ----------- ----------- BLDIAG6 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLDIAG6 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLDIAG6 1115 ----------- ----------- ----------- ----------- SCCPHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SCCPHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 SCCPHC 1115 ----------- ----------- ----------- ----------- BLBSMG 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLBSMG 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLBSMG 1115 ----------- ----------- ----------- ----------- SLANHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SLANHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 SLANHC 1115 ----------- ----------- ----------- ----------- ERTHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 ERTHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 ERTHC 1115 ----------- ----------- ----------- ----------- IPSHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPSHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPSHC 1115 ----------- ----------- ----------- ----------- ATMHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 ATMHC 1116 134-003-000 134-002-000 134-002-000 134-003-000 ATMHC 1115 ----------- ----------- ----------- ----------- IPSG 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPSG 1116 134-003-000 134-002-000 134-002-000 134-003-000 IPSG 1115 ----------- ----------- ----------- ----------- BLROM1 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLROM1 1116 134-003-000 134-002-000 134-002-000 134-003-000 BLROM1 1115 ----------- ----------- ----------- ----------- BLIXP 1114 163-003-000 163-003-000 163-002-000 163-003-000 BLIXP 1116 163-003-000 163-002-000 163-002-000 163-003-000 BLIXP 1115 ----------- ----------- ----------- -----------
This example shows GPLs on an EAGLE that has E5-based control cards installed. The GPLs were copied from the removable media in on the active MASP. The USB credit card flash media is not inserted into the USB credit card flash media drive in the E5-MCAP card of the active MASP (card location 1115).
init-card command specifying the location of the E5-MCAP card making up active MASP. This step makes the standby MASP the active MASP. The MASP that was active is now the standby MASP.
For this example, enter this command.
init-card:loc=1115
This message should appear.
rlghncxa03w 09-10-01 11:11:28 GMT EAGLE5 41.1.0 Init Card command issued to card 1115
copy-gpl command. Perform the following substep:copy-gpl:sloc=1113:dloc=1116:sdrv=remove
rtrv-gpl command. This is an example of the possible output.
rlghncxa03w 8-12-13 07:01:08 GMT EAGLE5 45.0.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL SIPHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SIPHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 SIPHC 1115 ----------- ----------- ----------- ----------- GLS 1114 134-003-000 134-003-000 134-002-000 134-003-000 GLS 1116 134-003-000 134-003-000 134-002-000 134-003-000 GLS 1115 ----------- ----------- ----------- ----------- CDU 1114 163-001-000 163-001-000 163-000-000 163-001-000 CDU 1116 163-001-000 163-001-000 163-000-000 163-001-000 CDU 1115 ----------- ----------- ----------- ----------- IMT 1114 134-003-000 134-003-000 134-002-000 134-003-000 IMT 1116 134-003-000 134-003-000 134-002-000 134-003-000 IMT 1115 ----------- ----------- ----------- ----------- ATMANSI 1114 134-003-000 134-003-000 134-002-000 134-003-000 ATMANSI 1116 134-003-000 134-003-000 134-002-000 134-003-000 ATMANSI 1115 ----------- ----------- ----------- ----------- BPHCAP 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPHCAP 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPHCAP 1115 ----------- ----------- ----------- ----------- BPDCM 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPDCM 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPDCM 1115 ----------- ----------- ----------- ----------- BLMCAP 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLMCAP 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLMCAP 1115 ----------- ----------- ----------- ----------- OAMHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 OAMHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 OAMHC 1115 ----------- ----------- ----------- ----------- HIPR2 1114 134-003-000 134-003-000 134-002-000 134-003-000 HIPR2 1116 134-003-000 134-003-000 134-002-000 134-003-000 HIPR2 1115 ----------- ----------- ----------- ----------- VXWSLAN 1114 134-003-000 134-003-000 134-002-000 134-003-000 VXWSLAN 1116 134-003-000 134-003-000 134-002-000 134-003-000 VXWSLAN 1115 ----------- ----------- ----------- ----------- IPLIM 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPLIM 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPLIM 1115 ----------- ----------- ----------- ----------- IPLIMI 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPLIMI 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPLIMI 1115 ----------- ----------- ----------- ----------- SS7IPGW 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7IPGW 1116 134-003-000 134-003-000 134-002-000 134-003-000 SS7IPGW 1115 ----------- ----------- ----------- ----------- VSCCP 1114 134-003-000 134-003-000 134-002-000 134-003-000 VSCCP 1116 134-003-000 134-003-000 134-002-000 134-003-000 VSCCP 1115 ----------- ----------- ----------- ----------- ATMITU 1114 134-003-000 134-003-000 134-002-000 134-003-000 ATMITU 1116 134-003-000 134-003-000 134-002-000 134-003-000 ATMITU 1115 ----------- ----------- ----------- ----------- VCDU 1114 163-001-000 163-001-000 163-000-000 163-001-000 VCDU 1116 163-001-000 163-001-000 163-000-000 163-001-000 VCDU 1115 ----------- ----------- ----------- ----------- BPMPL 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPMPL 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPMPL 1115 ----------- ----------- ----------- ----------- SS7ML 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7ML 1116 134-003-000 134-003-000 134-002-000 134-003-000 SS7ML 1115 ----------- ----------- ----------- ----------- BPHMUX 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPHMUX 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPHMUX 1115 ----------- ----------- ----------- ----------- IPGWI 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPGWI 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPGWI 1115 ----------- ----------- ----------- ----------- IPS 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPS 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPS 1115 ----------- ----------- ----------- ----------- BPDCM2 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPDCM2 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPDCM2 1115 ----------- ----------- ----------- ----------- EROUTE 1114 134-003-000 134-003-000 134-002-000 134-003-000 EROUTE 1116 134-003-000 134-003-000 134-002-000 134-003-000 EROUTE 1115 ----------- ---------- ----------- ----------- BPMPLT 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPMPLT 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPMPLT 1115 ----------- ----------- ----------- ----------- MCP 1114 134-003-000 134-003-000 134-002-000 134-003-000 MCP 1116 134-003-000 134-003-000 134-002-000 134-003-000 MCP 1115 ----------- ----------- ----------- ----------- BPHCAPT 1114 134-003-000 134-003-000 134-002-000 134-003-000 BPHCAPT 1116 134-003-000 134-003-000 134-002-000 134-003-000 BPHCAPT 1115 ----------- ----------- ----------- ----------- SS7HC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7HC 1116 134-003-000 134-003-000 134-002-000 134-003-000 SS7HC 1115 ----------- ----------- ----------- ----------- BLBIOS 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLBIOS 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLBIOS 1115 ----------- ----------- ----------- ----------- BLCPLD 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLCPLD 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLCPLD 1115 ----------- ----------- ----------- ----------- GLSHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 GLSHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 GLSHC 1115 ----------- ----------- ----------- ----------- IMTPCI 1114 134-003-000 134-003-000 134-002-000 134-003-000 IMTPCI 1116 134-003-000 134-003-000 134-002-000 134-003-000 IMTPCI 1115 ----------- ----------- ----------- ----------- PLDPMC1 1114 134-003-000 134-003-000 134-002-000 134-003-000 PLDPMC1 1116 134-003-000 134-003-000 134-002-000 134-003-000 PLDPMC1 1115 ----------- ----------- ----------- ----------- IPLHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPLHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPLHC 1115 ----------- ----------- ----------- ----------- IPGHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPGHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPGHC 1115 ----------- ----------- ----------- ----------- SS7EPM 1114 134-003-000 134-003-000 134-002-000 134-003-000 SS7EPM 1116 134-003-000 134-003-000 134-002-000 134-003-000 SS7EPM 1115 ----------- ----------- ----------- ----------- BLBEPM 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLBEPM 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLBEPM 1115 ----------- ----------- ----------- ----------- BLVXW6 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLVXW6 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLVXW6 1115 ----------- ----------- ----------- ----------- BLDIAG6 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLDIAG6 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLDIAG6 1115 ----------- ----------- ----------- ----------- SCCPHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SCCPHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 SCCPHC 1115 ----------- ----------- ----------- ----------- BLBSMG 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLBSMG 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLBSMG 1115 ----------- ----------- ----------- ----------- SLANHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 SLANHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 SLANHC 1115 ----------- ----------- ----------- ----------- ERTHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 ERTHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 ERTHC 1115 ----------- ----------- ----------- ----------- IPSHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPSHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPSHC 1115 ----------- ----------- ----------- ----------- ATMHC 1114 134-003-000 134-003-000 134-002-000 134-003-000 ATMHC 1116 134-003-000 134-003-000 134-002-000 134-003-000 ATMHC 1115 ----------- ----------- ----------- ----------- IPSG 1114 134-003-000 134-003-000 134-002-000 134-003-000 IPSG 1116 134-003-000 134-003-000 134-002-000 134-003-000 IPSG 1115 ----------- ----------- ----------- ----------- BLROM1 1114 134-003-000 134-003-000 134-002-000 134-003-000 BLROM1 1116 134-003-000 134-003-000 134-002-000 134-003-000 BLROM1 1115 ----------- ----------- ----------- ----------- BLIXP 1114 163-003-000 163-003-000 163-002-000 163-003-000 BLIXP 1116 163-003-000 163-003-000 163-002-000 163-003-000 BLIXP 1115 ----------- ----------- ----------- -----------
This procedure is finished.
Figure 2-12 Restoring System Data from a Removable Cartridge or Removable Media
Sheet 1 of 2
Sheet 2 of 2
