| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This section details the procedure used to make a backup copy of the system data in addition to the database.
The term “database” refers to all data that can be administered by the user, including shelves, cards, links, routes, global title translation tables, and gateway screening tables. The term “system data” refers to data that cannot be administered by the user, including maintenance software modules and generic program loads (GPLs).
copy-gpl command.
Perform the following substep.
copy-gpl:sloc=1116:dloc=1115:ddrv=remove
During command execution, these messages should appear.
rlghncxa03w 09-03-01 14:50:46 GMT EAGLE5 40.1.0
COPY-GPL: MASP B - COPY STARTS ON ACTIVE MASP
COPY GPL: MASP B - COPY TO REMOVABLE DRIVE COMPLETE
rtrv-gpl command.
This is an example of the possible output.
tekelecstp 18-01-18 21:23:11 EST EAGLE 46.5.1.5.0-73.10.0
rtrv-gpl
Command entered at terminal #18.
Command Accepted - Processing
GPL Auditing ON
GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL
OAMHC 1114 143-010-000 143-010-000 ALM ----------- -----------
OAMHC 1116 143-010-000 143-010-000 ALM ----------- -----------
OAMHC 1115 ----------- ----------- ----------- -----------
OAMHC69 1114 143-010-000 143-010-000 ALM ----------- -----------
OAMHC69 1116 143-010-000 143-010-000 ALM ----------- -----------
OAMHC69 1115 ----------- ----------- ----------- -----------
IPSG32 1114 143-010-000 143-010-000 143-010-000 -----------
IPSG32 1116 143-010-000 143-010-000 143-010-000 -----------
IPSG32 1115 ----------- ----------- ----------- -----------
BLMCAP 1114 143-010-000 143-010-000 143-010-000 -----------
BLMCAP 1116 143-010-000 143-010-000 143-010-000 -----------
BLMCAP 1115 ----------- ----------- ----------- -----------
HIPR2 1114 143-010-000 143-010-000 143-010-000 -----------
HIPR2 1116 143-010-000 143-010-000 143-010-000 -----------
HIPR2 1115 ----------- ----------- ----------- -----------
SFAPP 1114 143-010-000 143-010-000 ALM 143-010-000 -----------
SFAPP 1116 143-010-000 143-010-000 ALM 143-010-000 -----------
SFAPP 1115 ----------- ----------- ----------- -----------
SS7HC 1114 143-010-000 143-010-000 143-010-000 -----------
SS7HC 1116 143-010-000 143-010-000 143-010-000 -----------
SS7HC 1115 ----------- ----------- ----------- -----------
SCCPHC 1114 143-010-000 143-010-000 143-010-000 -----------
SCCPHC 1116 143-010-000 143-010-000 143-010-000 -----------
SCCPHC 1115 ----------- ----------- ----------- -----------
ERTHC 1114 143-010-000 143-010-000 143-010-000 -----------
ERTHC 1116 143-010-000 143-010-000 143-010-000 -----------
ERTHC 1115 ----------- ----------- ----------- -----------
IPSHC 1114 143-010-000 143-010-000 143-010-000 -----------
IPSHC 1116 143-010-000 143-010-000 143-010-000 -----------
IPSHC 1115 ----------- ----------- ----------- -----------
ATMHC 1114 143-010-000 143-010-000 143-010-000 -----------
ATMHC 1116 143-010-000 143-010-000 143-010-000 -----------
ATMHC 1115 ----------- ----------- ----------- -----------
IPSG 1114 143-010-000 143-010-000 143-010-000 -----------
IPSG 1116 143-010-000 143-010-000 143-010-000 -----------
IPSG 1115 ----------- ----------- ----------- -----------
PKTGHC 1114 143-010-000 143-010-000 ----------- -----------
PKTGHC 1116 143-010-000 143-010-000 ----------- -----------
PKTGHC 1115 ----------- ----------- ----------- -----------
BLIXP 1114 143-010-000 143-010-000 143-010-000 -----------
BLIXP 1116 143-010-000 143-010-000 143-010-000 -----------
BLIXP 1115 ----------- ----------- ----------- -----------
MCPHC 1114 143-010-000 143-010-000 143-010-000 -----------
MCPHC 1116 143-010-000 143-010-000 143-010-000 -----------
MCPHC 1115 ----------- ----------- ----------- -----------
SIPHC 1114 143-010-000 143-010-000 143-010-000 -----------
SIPHC 1116 143-010-000 143-010-000 143-010-000 -----------
SIPHC 1115 ----------- ----------- ----------- -----------
DEIRHC 1114 143-010-000 143-010-000 143-010-000 -----------
DEIRHC 1116 143-010-000 143-010-000 143-010-000 -----------
DEIRHC 1115 ----------- ----------- ----------- -----------
ENUMHC 1114 143-010-000 143-010-000 143-010-000 -----------
ENUMHC 1116 143-010-000 143-010-000 143-010-000 -----------
ENUMHC 1115 ----------- ----------- ----------- -----------
PKTG64 1114 143-010-000 143-010-000 ----------- -----------
PKTG64 1116 143-010-000 143-010-000 ----------- -----------
PKTG64 1115 ----------- ----------- ----------- -----------
BLDC64 1114 143-010-000 ----------- 143-010-000 -----------
BLDC64 1116 143-010-000 000-000-000 ALM 143-010-000 -----------
BLDC64 1115 ----------- ----------- ----------- -----------
SCCP64 1114 143-010-000 143-010-000 143-010-000 -----------
SCCP64 1116 143-010-000 143-010-000 143-010-000 -----------
SCCP64 1115 ----------- ----------- ----------- -----------
BLSLC32 1114 143-010-000 143-010-000 143-010-000 -----------
BLSLC32 1116 143-010-000 143-010-000 143-010-000 -----------
BLSLC32 1115 ----------- ----------- ----------- -----------
BLSLC64 1114 143-010-000 143-010-000 143-010-000 -----------
BLSLC64 1116 143-010-000 143-010-000 143-010-000 -----------
BLSLC64 1115 ----------- ----------- ----------- -----------
SIP64 1114 143-010-000 143-010-000 143-010-000 -----------
SIP64 1116 143-010-000 143-010-000 143-010-000 -----------
SIP64 1115 ----------- ----------- ----------- -----------
DEIR64 1114 143-010-000 143-010-000 143-010-000 -----------
DEIR64 1116 143-010-000 143-010-000 143-010-000 -----------
DEIR64 1115 ----------- ----------- ----------- -----------
ENUM64 1114 143-010-000 143-010-000 143-010-000 -----------
ENUM64 1116 143-010-000 143-010-000 143-010-000 -----------
ENUM64 1115 ----------- ----------- ----------- -----------
BLDC32 1114 143-010-000 ----------- 143-010-000 -----------
BLDC32 1116 143-010-000 ----------- 143-010-000 -----------
BLDC32 1115 ----------- ----------- ----------- -----------
MCPHC69 1114 143-010-000 143-010-000 143-010-000 -----------
MCPHC69 1116 143-010-000 143-010-000 143-010-000 -----------
MCPHC69 1115 ----------- ----------- ----------- -----------
IPSHC69 1114 143-010-000 143-010-000 143-010-000 -----------
IPSHC69 1116 143-010-000 143-010-000 143-010-000 -----------
IPSHC69 1115 ----------- ----------- ----------- -----------
BLSL932 1114 143-010-000 143-010-000 143-010-000 -----------
BLSL932 1116 143-010-000 143-010-000 143-010-000 -----------
BLSL932 1115 ----------- ----------- ----------- -----------
Command Executed
This example shows GPLs on an EAGLE that has E5-based control cards installed. The GPLs were copied to the removable media in both MASPs. The USB credit card flash media is not inserted into the USB credit card flash media drive in the E5-MCAP card of the active MASP (card location 1115). If the GPLs were copied only to the removable media on the active MASP, the removable media is not inserted in the standby MASP and the GPL version number for the standby MASP is not displayed.
Remove the removable media from the removable media drives on the MASPs. For more information on removing the removable media from the removable media drives, refer to Removable USB Drive.
For more information on labeling the removable media, see Chapter 2, “Preventive Maintenance,” in Maintenance Guide.
