| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to make a backup of the database to the or removable media using the chg-db command with the action=backup and dest=remove parameters.
The database in the current partition of the active MASP (FD CRNT) must be coherent. For more information on verifying the database, refer to Verifying the Database.
Formatting blank removable media for E5-based control cards that are installed in the EAGLE is required. If the removable media is not formatted, perform Formatting Removable Media to format the media.
rept-stat-db command. This is an example of the possible output.
rlghncxa03w 06-10-13 16:07:48 GMT EAGLE5 45.0.0
DATABASE STATUS: >> OK <<
E5TDM 1114 ( STDBY) E5TDM 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 35 04-06-01 10:19:18 GMT Y 35 04-06-01 10:19:18 GMT
FD CRNT Y 106 Y 106
E5MDAL 1117
RD BKUP - - - -
The following is an example of the possible output.
rlghncxa03w 06-03-13 16:07:48 GMT EAGLE5 45.0.0
E5TDM 1114 ( STDBY ) E5TDM 1116 ( ACTV )
FD BKUP Y 35 09-02-19 10:19:18 GMT Y 35 09-02-19 10:19:18 GMT
FD CRNT Y 106 Y 106
E5MCAP 1113 E5MCAP 1115
RD BKUP - - - - - - - -
USB BKP - - - - - - - -
If the database in the current partition of the active MASP is not coherent, refer to Verifying the Database to resolve the database problem.
If the database in the current partition of the active MASP is coherent, or after the database problem has been resolved, continue the procedure by performing one of these steps.
Perform one of these substeps.
If the removable media drives in both MASPs are empty, insert the media that will be used for the backup. Refer to Removable USB Drive for information about inserting the removable media. After the media has been inserted into the removable media drives, continue the procedure with 3.
If removable media is inserted into the removable media drive on active MASP and no removable media is inserted into the removable media drive on the standby MASP, and this media will be used for the backup, continue the procedure with 3. When the backup is performed, the database in the current partition of the fixed disk on the active MASP is copied to the removable media on the active MASP.
If removable media is inserted into the removable media drive on active MASP and no removable media is inserted into the removable media drive on the standby MASP, and this media will not be used for the backup, remove the media from the removable media drive and insert the media that will be used for the backup into the removable media drive on the active MASP. After the media has been inserted, continue the procedure with 3.
If removable media is inserted into the removable media drive on standby MASP and no removable media is inserted into the removable media drive on the active MASP, remove the media from the removable media drive and insert the media that will be used for the backup into the removable media drive on the active MASP. After the media has been inserted, continue the procedure with 3.
If removable media drives in both MASPs are empty, insert the media that will be used for the backup into the removable media drive on the active MASP. After the media has been inserted, continue the procedure with 3.
chg-db:action=backup:dest=remove
During command execution, these messages should appear.
BACKUP (REMOVABLE) : MASP A - Backup starts on active MASP. BACKUP (REMOVABLE) : MASP A - Backup to removable device complete.
This command can take up to 30 minutes to execute, depending on the size of the database and other system activity that is in progress when this command is entered. If this command takes more than 60 minutes to execute, contact the Customer Care Center for assistance. Refer to My Oracle Support (MOS) for the contact information.rept-stat-db command. If the database was backed up to the removable media, this is an example of the possible output.
rlghncxa03w 06-03-13 16:07:48 GMT EAGLE5 45.5.0
FD CRNT Y 106 Y 106
RD BKUP Y 106 09-03-23 16:09:53 GMT Y 106 09-03-23 16:09:53 GMT
If the database was backed up to only the removable media on the active MASP, then only the RD BKUP entry for the active MASP (in this example, MCAP 1115) is displayed.For more information on labeling the removable media, see Chapter 2, “Preventive Maintenance,” in Maintenance Guide.
Figure 2-5 Making a Backup of the Database to the Removable Cartridge or Removable Media
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
