| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
Use this procedure to prepare removable media for use on
the EAGLE for holding system data or measurements data using the
format-disk command. The
format-disk command uses these
parameters.
This procedure can be performed only if E5-based control cards are installed in the EAGLE. Refer to Maintenance and Administration Subsystem for more information about the control cards.:type – The type of
media that is being formatted.
system – Removable
media containing system data (GPLs and the database)
meas – Removable
media containing measurements data
fixed – The fixed
disk of the standby
E5-TDM. To format the
fixed disk of the standby
E5-TDM, perform
Formatting the Fixed Disk of the Standby E5-TDM.
:loc – The location of
the E5-MCAP card that contains the media that is being formatted, either 1113
or 1115.
:low – Is a check of
the media being performed and any problems found on the media being repaired,
yes or
no? The
low=yes parameter performs a check of
the media and any problems that are found are repaired. No data is destroyed
during this operation. If the
low=no parameter is specified, the
check of the media is not performed. The default value for this parameter is
no.
:force – Format the
media if the media contains system data,
yes or
no. The default value for this
parameter is
no.
:prtngrp – Indicates
which disk partition group is being formatted, the active partition group
(prtngrp=active) or the inactive partition
group (prtngrp=inactive). The default value
for the
prtngrp parameter is
active. The removable media does not
contain an inactive partition group, so the
prtngrp=inactive cannot be specified
in this procedure.
Reduce extended execution time when specifying theforce=yes option by also using the
low=no option.
The database in the current (FD CRNT) partition of the active MASP must be coherent. If the current partition of the active MASP is not coherent, contact the customer care center. Refer to My Oracle Support (MOS) for the contact information.
Measurement collection must be turned off before the
format-disk command can be executed.
Figure 2-14 Formatting Removable Media
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
