| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to add an entry to the frame power alarm threshold table. The frame power alarm threshold table defines the power level threshold, in amps, for each frame in the EAGLE. The power level threshold determines when alarms regarding the amount of power used by the frame are generated. Three alarms can be generated for the power levels.
More information on these alarms is shown in Unsolicited Alarm and Information Messages Reference.
The power alarm threshold table for each frame is configured using the ent-frm-pwr command with these parameters:
:frm – The name of the frame being added to the power alarm threshold table, cf00, ef00, ef01, ef02, ef03, or ef04.
:thrshld – The power threshold value, from 30 to 65 amps.
The frame being added in this procedure must be configured in the database. This can be verified by displaying the shelves in the EAGLE with the rtrv-shlf command. The number assigned to each configured frame is shown in the SHELF FRAME column of the rtrv-shlf output. Table 4-6 shows the name of each frame used in the Frame Power Alarm Threshold table and the corresponding frame number shown in the SHELF FRAME column of the rtrv-shlf output.
Table 4-6 Frame Power Alarm Threshold Table Frame Designations
| Name of the Frame in the Frame Power Alarm Threshold Table | Frame Numbers shown in the Shelf Frame Column of the RTRV-SHLF Output |
| CF00 |
1 |
| EF00 |
2 |
| EF01 |
3 |
| EF02 |
4 |
| EF03 |
5 |
| EF04 |
6 |
The thrshld parameter is optional. If the thrshld parameter value is not specified, the thrshld value is set to 30.
Figure 4-30 Adding an Entry to the Frame Power Alarm Threshold Table
Sheet 1 of 2
Sheet 2 of 2
