- Alarms and Maintenance Guide
- Field Replaceable Units
- Increasing Data Capacity with 480G Drive Modules
If 300G drive modules were in use when EPAP was installed, EPAP must be re-installed to take advantage of the additional storage capacity available on 480G drive modules.
Procedure - Increase Data Capacity with 480G Drive Modules
- Backup the data and configurations of the existing
setup.
Perform the following procedures for data backup and configurations:
- Pre Full Upgrade
Steps
- SETTING UP PRE-FULL UPGRADE ENVIRONMENT
- CAPTURING CURRENT CONFIGURATIONS
- CAPTURING CURRENT CONFIGURATIONS ON STANDALONE EPAP
- PRE-FULL UPGRADE CHECK
- Data Backup before
Full Upgrade
- SHUTTING DOWN THE PDBA AND EPAP
- DISABLE EPAP VIP AND DEACTIVATE PDBA PROXY FEATURE
- STOP ACTIVE PDBA AND VERIFY PDBA REPLICATION STATUS
- DISCONNECT REMOTE PDBA
- BACKUP EUIDB DATABASE
- BACKUP PDB
- BACKUP RTDB DATABASE
- STOP MYSQL SERVICE
- TRANSFER DATABASES TO MATE AND REMOTE
- Pre Full Upgrade
Steps
- If you have not already replaced both 300G drive modules with 480G drive modules, remove the 300G drive modules from the E5-APP-B card.
modules with 480G drive modules, insert the new 480G drive modules.
See steps 1 through 4 in Replacing a Drive Module Assembly.
- After the drive modules are successfully replaced,
IPM the drive modules with the latest TPD and install EPAP.
Perform the following procedures for IPM and EPAP installation:
- PRE INSTALL CONFIGURATION
- EPAP INSTALLATION
- Perform initial configuration and data migration to
complete the procedure.
Perform the following procedures for initial configuration and data migration:
- Initial
Configuration
- CONFIGURE NETWORK INTERFACE USING PLATCFG UTILITY
- CONFIGURE NETWORK INTERFACES
- RESTORE EUIDB DATABASE
- CONFIGURE PROVISIONING NETWORK
- VERIFY CONFIGURATIONS
- CONFIGURE NTP SERVERS
- POST CONFIGURATION SYSCHECK
- REBOOT THE MPS
- Data Migration
- RESTORE PDB
- RESTORE AND CONVERT RTDB
- VERIFY PDBA AND RTDB ARE IN SYNC
- RELOAD RTDB FROM MATE
- POINT ACTIVE PDB (2A) TO UPGRADED STANDBY PDB (1A)
- SET SPECIFIC RTDB HOMING
- POINT STANDBY PDB (1A) TO ACTIVE PDB (2A)
- RESTART THE PDBA AND EPAP
- UPDATE PDB CONFIGURATION
- EXCHANGE KEYS BETWEEN PROVISIONABLE AND NONPROVISIONABLE SERVERS USING SCRIPT
- ENABLE EPAP PDBA PROXY AND EPAP VIP OPTIONAL FEATURES
- CONFIGURE THE AUTO BACKUP
- SWITCHOVER PDBA
- CHECK REPLICATION BETWEEN ACTIVE AND STANDBY PDBA
- Initial
Configuration
