Viewing IPSec Statistics
The following section explains the commands used to obtain IPSec statistics which can be helpful for debugging purposes.
Security Association Entries
The ACLI show security ipsec sad command displays the security association database entries which are programmed into the security processor. In the case of manual keying, the entries should match that of the running configuration. Network-interface is entered as a network interface configuration element name, selectors are entered as the selector term, a <space>, and a search term for that selector. You can enter multiple selector in one command. The command's syntax follows:
show security ipsec sad [network-interface] <brief | detail> [selectors]
Entering no selectors returns all entries for that network interface. Valid values for the selectors argument are as follows:
- direction—Direction (IN | OUT | BOTH), Default: BOTH
- dst-addr-prefix—Destination address prefix, Default: match any
- dst-port—Destination port, Default: match any
- ipsec-protocol—IPSec protocol (AH | ESP | ALL), Default: ALL
- spi—security-policy-index, Default: match any
- src-addr-prefix—Source address prefix, Default: match any
- src-port—Source port, Default: match any
- trans-proto—Transport protocol (UDP | TCP | ICMP | ALL), Default: ALL
Security Policy Entries
The show security ipsec spd command shows the security policy database entries which are programmed into the security processor. Network-interface is entered as a network interface configuration element name. The command's syntax follows:
show security ipsec spd [network-interface]
IPSec Statistics
The ACLI show commands for IPSec statistics are used to display statistical values as reported directly from the IPSec hardware. There are two versions of this command:
- The show security ipsec statistics sad command queries a selected IPSec processor for statistics about the SAs configured on it, as located in the security association database (SAD).
- The show security ipsec statistics gmac command queries the GMAC side of the security processor for Ethernet statistics.
Viewing Statistics for a Specific SA
The show security ipsec statistics sad command shows statistical values for a particular SA entry on the IPSec security processor. You enter a network interface configuration name, selectors by the selector term, a Space, and a search term for that selector. You can enter multiple selector in one command. The command's syntax follows:
show security ipsec statistics [network-interface] sad <selectors>
Viewing Statistic for Traffic to from the GMAC Interface and the Security Processor
The show security ipsec statistics gmac command displays statistics on traffic that moves between the GMAC interface and the security processor on a specified network interface. Network-interface is entered as a network interface configuration element name. You can display either errors, transmit statistics, receive statistics, or all statistics per HW accelerator / gmac interface . The command's syntax follows:
show security ipsec statistics [network-interface] gmac <enter | error | rx | tx>
Viewing IPSec Interface Status
The show security ipsec status command displays whether a particular interface on Oracle Communications Session Border Controller is IPSec enabled, and the hardware status of the security processor. Network-interface is entered as a network interface configuration element name. The show security ipsec status command usage is as follows:
show security ipsec status [network-interface]
