Viewing TLS Information
You can use the commands described in this section to obtain information about TLS and its associated Acme Packet SSM hardware module.
Viewing TLS Session Cache State and Statistics
To see whether TLS session caching is enabled on your system and how many entries there are in the cache:
Viewing Certificates in PEM Form
The ACLI show certificates command has been enhanced to provide a pem argument that you can use to retrieve the Privacy Enhanced Mail Security Certificate (PEM) portion of the certificate after it the Oracle Communications Session Border Controller has imported it.
You enter this command with the name of the certificate you want to see in PEM form.
To see a certificate in PEM form:
Viewing SSM Status
For TLS support, you must have an Oracle SSM hardware module installed in the system chassis. Without this module, TLS functions will not work.
The Oracle Communications Session Border Controller tells you whether or not the SSM installed on boot-up, but now you can check the module’s status from the command line.
To view the status of the SSM installed in your Oracle Communications Session Border Controller chassis:
