Monitoring Your Net-Net System in Real-Time
This section explains how to monitor your system in real-time by using the monitor media and monitor sessions commands.
- monitor media: real-time media statistics
- monitor sessions: real-time SIP statistics
The ACLI statistics displays use standard VT100 escape sequences to format the display. Therefore, your terminal emulator or terminal itself must support VT100.
Displaying the Statistics
The following information explains how to work with the statistics display.
Changing the Refresh Rate
At any point, you can press any numerical digit (0-9) to change the number of seconds for the refresh rate (the rate at which the display is updated). By default, the statistics refresh every second. For example, while viewing the statistics, you can press 6 to cause the system statistics to refresh every 6 seconds. While viewing the statistics via the ACLI, you can press any key to automatically refresh the statistics upon key press.
Viewing Real-Time Media Statistics
Display real-time media statistics for your running system by using the monitor media command.
acmepacket# monitor media
17:31:00-160
MBCD Status -- Period -- -------- Lifetime --------
Active High Total Total PerMax High
Client Sessions 143 182 1930 1218332 4225 683
Client Trans 0 18 5744 2500196 8439 625
Contexts 144 182 1930 834745 2783 2001
Flows 296 372 3860 1669498 5566 3689
Flow-Port 286 362 3860 1669488 5566 3679
Flow-NAT 294 365 3788 1658668 5563 2051
Flow-RTCP 0 0 0 0 0 0
Flow-Hairpin 0 0 0 0 0 0
Flow-Released 0 0 0 0 0 0
MSM-Release 0 0 0 0 0 0
NAT Entries 295 365 3791 1658671 5563 2051
Free Ports 7430 7518 7828 3346410 11604 8002
Used Ports 572 724 7724 3338980 11132 8000
Port Sorts - - 0 14796 4156
MBC Trans 1141 1234 5748 2503147 8440 2974
MBC Ignored - - 0 0 0
ARP Trans 0 0 0 8 8 1
Real-time statistics for the following categories appear on the screen:
- Client Sessions
- Client Trans
- Contexts
- Flows
- Flow-Port
- Flow-NAT
- Flow-RTCP
- Flow-Hairpin
- Flow-Release
- MSM-Release
- NAT Entries
- Free Ports
- Used Ports
- Port Sorts
- MBC Trans
- MBC Ignored
- ARP Trans
By default, the statistics refresh every second. Press any numerical digit (0-9) to change the refresh rate. For example while viewing the statistics, you can press 6 to cause the system statistics to refresh every 6 seconds.
Pressing q or Q allows you to exit the statistics display and returns you to the ACLI system prompt.
Viewing Real-Time SIP Session Statistics
If you have Superuser access, display real-time monitoring of your running system for sessions. This table displays information similar to that which is displayed for the show sipd command, except that the information in the monitor sessions table is real-time and updates automatically.
ORACLE# show sipd 14:16:43-149 SIP Status -- Period -- -------- Lifetime -------- Active High Total Total PerMax High Sessions 0 0 0 0 0 0 Subscriptions 0 0 0 0 0 0 Dialogs 0 0 0 0 0 0 CallID Map 0 0 0 0 0 0 Rejections - - 0 0 0 ReINVITEs - - 0 0 0 Media Sessions 0 0 0 0 0 0 Media Pending 0 0 0 0 0 0 Client Trans 0 0 0 0 0 0 Server Trans 0 0 0 0 0 0 Resp Contexts 0 0 0 0 0 0 Saved Contexts 0 0 0 0 0 0 Sockets 0 0 0 0 0 0 Req Dropped - - 0 0 0 DNS Trans 0 0 0 0 0 0 DNS Sockets 0 0 0 0 0 0 DNS Results 0 0 0 0 0 0 Session Rate = 0.0 Load Rate = 0.0
- Dialogs
- Sessions
- CallID Map
- Rejections
- ReINVITES
- Media Sessions
- Media Pending
- Client Trans
- Server Trans
- Resp Contexts
- Sockets
- Reqs Dropped
- DNS Trans
- DNS Sockets
- DNS Results
By default, the statistics refresh every second. Press any numerical digit (0-9) to change the refresh rate. For example, while viewing the statistics, you can press 6 to cause the system statistics to refresh every 6 seconds.
Thread Level Load Monitoring and Alarms
The Oracle Communications Session Border Controller provides a thread-level monitoring for CPU usage, specifically including three critical traffic processes: SIP, ATCP and MBCD.
Several mechanisms are available for monitoring CPU usage on a per-thread basis: ACLI commands, alarms, HDR, traps and MIBs. The thread usage table MIB object is found in ap-usbcsys.mib. It supports the output of process and thread utilization information. HDR information is produced as a comma separated value file whose data can be displayed in a formatted fashion via command line. The system sends SNMP traps when any of the SIP, ATCP worker threads or MBCD tasks exceed configured thresholds. Users can construct a Threshold Crossing Alarm (TCA) which issues minor, major and critical system alarms when the thread usage level exceeds pre-configured values. These Thread Overload Alarms follow the example in the Configurable Alarm Thresholds and Traps section.
ACLI
- show processes: add sipd, atpcd and overload arguments
- show queues atcpd
- show queues sipd
Alarms
The user-configurable alarm may be created to notify the user of any problematic usage of CPU resources by specific processes at a thread-level basis.
To create alarms, the user sets the with the following values to create the corresponding threshold crossing alarm.
- cpu-sipd
- cpu-atcp
- cpu-mbcd
When a thread alarm is active due to crossing a pre-configured threshold, the system sends the apUsbcSysThreadUsageExceededTrap trap.
When the thread's load falls below the threshold that triggered the alarm, the system sends the apUsbcSysThreadUsageClearTrap trap.
The user can get this information using the display-alarms command.
Historic Data Recording (HDR)
There are two HDR groups available to record Thread Level Load Monitoring information:
- thread-event: reports pending and dropped events per protocol as well as calculating latency
- thread-usage: reports CPU thread usage per protocol and an overload condition
The data captured by these two HDR groups corresponds to the show queues atcpd and show queues sipd ACLI command output.
SNMP MIBs and Traps
Thread Level Load Monitoring information can be retrieved via SNMP by from MIB objects in the
ap-usbcsys.mib. In addition, traps are available to send off-system notifications.
There are two types of traps that provide process-level thread threshold indicators.
- Traps managed by the process-level thread alarm configurations, which use the alarm configuration as triggers. These traps include:
- apUsbcSysThreadUsageExceededTrap
- apUsbcSysThreadUsageClearTrap
- Traps managed by Symmetric Multi-processing (SMP)-aware task load limiting function's configurations, which use the use the SMP Transport, SIP and Media limiting configurations as triggers. These traps include:
- apUsbcSysThreadUsageOverloadEnableTrap
- apUsbcSysThreadUsageOverloadDisableTrap
Information in overload enable/disable traps include the threshold type, the overload alarm exceeded or cleared as well as the overload method activated or de-activated.
The system follows the SMP-Aware Task Load Limiting rules described in the Oracle® Communications Session Border Controller Troubleshooting and Maintenance Guide to determine the action(s) it takes when crossing these thresholds.
The system manages these traps by applying a function similar to CPU overloading limit to smooth the output and avoid issuing too many traps. Each trap contains the thread name. The usage exceeded trap also contains current thread usage.
For SIP, ACTP and MBCD, traps display the threshold type, the overload alarm exceeded or cleared, or the overload method activated or de-activated.
