Viewing Network Management Control Statistics
You can use the new ACLI show net-management-control command to see the statistics that the Oracle Communications Session Border Controller collects. When you use the command, you specify the name of the network management control rule for which you want to display data or you can enter all to see the statistics for all control rules.
For each network management control rule, the Oracle Communications Session Border Controller gathers statistics for the number of:
- Incoming calls—Incoming calls that match the destination identifier
- Rejected calls—Calls that were rejected as a result of the control rule being applied
- Diverted calls—Incoming that were diverted as a result of the control rule being applied
The display you see when you execute this command shows statistics for the current period, lifetime, and maximum value in a period.
Resetting Network Management Control Statistics
To reset network management control statistics, you use the ACLI reset net-management-control command followed by the name of the control rule for which you want to reset statistics. This command resets the counters to zero (0).
To reset network management control statistics:
