Configuration File Format
The functionality described in this section is of interest only to those users running a 6.3x software version which pre-dates S-C630F1 who want to downgrade to an earlier release. Other users can safely ignore this section.
Configuration files, referred to as config files, are stored in XML format. Releases prior to C630F1 saved certain special characters in a non-standard XML format. From release C630F1 and forward, these characters are saved in formats compliant with current W3C XML standards. Character formats are shown below.
| Character | Standard XML C63F1 (and after) | Non-Standard XML Pre C63F1 |
| ASCII hard tab | &#xp; | value 0x9 |
| ASCII line feed |
 | value 0xA |
| ASCII carriage return |
 | value 0xD |
| Ampersand | & | & |
| Less than | < | < |
| Greater than | > | > |
| Double quote | "e; | " |
| Single quote | ' | ' |
By default config files are now saved using standard XML coding. Consequently pre-C630F1 software images are unable to parse such config files, complicating the software downgrade process.
To address these complications, the save-config and backup-config ACLI commands has been enhanced to allow the saving of config files and backup configuration files in either standard XML or legacy, non-standard XML format.
save-config ACLI Command
By default, config files are saved in standard XML format that is non-parsable by a pre-C63F1 software image.
ORACLE# save-config checking configuration -------------------------------------------------------------------- Results of config verification: 2 configuration warnings Run 'verify-config' for more details --------------------------------------------------------------------- Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. ORACLE# verify-config --------------------------------------------------------------------- WARNING: security-policy [SP] local-ip-addr-match has 0.0.0.0. This is an acceptable configuration if intended. WARNING: security-policy [SP] remote-ip-addr-match has 0.0.0.0. This is an acceptable configuration if intended. --------------------------------------------------------------------- Total: 2 warnings ORACLE#
save-config, when used in conjunction with a newly supported argument, standard, also saves config files in standard XML format that is non-parsable by a pre-C63F1 software image.
ORACLE# save-config standard checking configuration -------------------------------------------------------------------- Results of config verification: 2 configuration warnings Run 'verify-config' for more details --------------------------------------------------------------------- Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. ORACLE# verify-config --------------------------------------------------------------------- WARNING: security-policy [SP] local-ip-addr-match has 0.0.0.0. This is an acceptable configuration if intended. WARNING: security-policy [SP] remote-ip-addr-match has 0.0.0.0. This is an acceptable configuration if intended. --------------------------------------------------------------------- Total: 2 warnings ORACLE#
save-config, when used in conjunction with a newly supported argument, non-standard, saves config files in legacy XML format that is parsable by a pre-C63F1 software image.
ORACLE# save-config non-standard checking configuration -------------------------------------------------------------------- Results of config verification: 2 configuration warnings Run 'verify-config' for more details --------------------------------------------------------------------- Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. ORACLE# verify-config --------------------------------------------------------------------- WARNING: security-policy [SP] local-ip-addr-match has 0.0.0.0. This is an acceptable configuration if intended. WARNING: security-policy [SP] remote-ip-addr-match has 0.0.0.0. This is an acceptable configuration if intended. --------------------------------------------------------------------- Total: 2 warnings ORACLE#
backup-config ACLI Command
By default, backup config files are saved in standard XML format that is non-parsable by a pre-C63F1 software image.
ORACLE# backup-config testBU task done ORACLE#
backup-config <filename> standard also saves backup config files in standard XML format that is non-parsable by a pre-C630F1 software image.
ORACLE# backup-config standardBU standard task done ORACLE#
backup-config <filename> non-standard saves backup config files in legacy XML format that is parsable by a pre-C63F1 software image.
ORACLE# backup-config nonStandardBU non-standard task done ORACLE#
The standard and non-standard optional arguments are not supported by the backup-config <filename> saved command, which takes the last saved version of config (whatever the XML format), and saves a copy of that file as the backup.
