System Prompt Indicator
Using the prompt-enabled command, you can enable a system prompt indicator to show you when a configuration requires saving and activation.
The system informs you should a configuration has been changed and you have applied the done command, but have not saved and activated yet. When you issue the done command and return to Superuser mode, the ACLI prompt prefixes two asterisks (**) . When you have saved but not yet activated, the ACLI prompted prefixes one asterisk (*). This command allows you to decide whether or not you want the system to give this prompt. To clarify:
- **—Requires save and activate
- *—Configuration saved, but requires activate
This feature is disabled by default.
