Realm-Specific Delete Command
The ACLI provides a way to delete a specific realm and the configurations (objects) associated with that realm. You use the delete realm-specifics command with the name of the realm you want to delete. Not only does the Oracle Communications Session Border Controller delete that realm, it also deletes the configurations where that realm is also used as a primary or foreign key—such as steering pools, session agents, and SIP interfaces. A complete list of configurations subject to deletion appears below.
The Oracle Communications Session Border Controller safeguards against unintentionally deleting configurations by showing you a complete list of the configurations it is about to delete, warns you that you are about to the delete the realm, and then asks you for confirmation. The list of candidates for deletion appears each with its key identifier so that you can more easily recognize it. You must type in a y for yes or n for no to move forward.
Despite these safeguards, you should use the delete realm-specifics command with the utmost care. Oracle recommends that only advanced users work with this command. In fact, the command appears in the configuration menu, to which only Superusers have access.
Deleted Configurations
This section provides a list of the configuration that use the name of realm either as a primary or as a foreign key. These are the configuration that you can remove from your configuration when you delete a specific realm.
| ACLI Configuration Name | ACLI Parameter Value |
| access-control | realm-id |
| call-recording-server | primary-realm
secondary-realm |
| dns-config | client-realm |
| enum-config | realm-id |
| ext-policy-server | realm |
| h323, h323-stack | realm-id |
| lawful-intercept | (associated parameters; specified in Oracle LI support documentation) |
| local-policy | source-realm |
| realm-config | identifier |
| session-agent | realm-id |
| sip-features | realm |
| sip-interface | realm-id |
| sip-nat | realm-id |
| static-flow | in-realm-id
out-realm-id |
| steering-pool | realm-id |
| surrogate-agent | realm-id |
There are configurations (objects) that use realms but do not reference them directly either as a primary or foreign key. The Oracle Communications Session Border Controller does not delete these configurations when you use the delete realm-specifics command:
- media-policy
- class-policy
- translation-rules
- sip-manipulation
This command cannot delete realms associated with network management control configurations.Deleted Parameter Values
For other configurations that reference realms, only the parameters containing realm identifiers are cleared while the object as a whole remains. By confirming you want to delete the realm, the Oracle Communications Session Border Controller clears the parameters set out in this section, the Oracle Communications Session Border Controller informs you of the configuration object and the parameter within it that will be affected.
The following table shows you which parameters are cleared.
| ACLI Configuration Name | ACLI Parameter Value(s) |
| dns-config | server-realm |
next-hop realm |
| media-manager | home-realm-id |
| realm-config | parent-realm
dns-realm ext-policy-svr |
| realm-group | source-realm
destination-realm |
| session-agent | egress-realm |
| session-group | dest |
| sip-config | egress-realm-id
home-realm-id |
Deleted Parameter Configuration
This section shows you how to use the delete realm-specifics command. Remember that you need to be in Superuser mode to use it.
To use the delete realm-specifics command, you need to know the identifier for the realm (and the other configurations associated with the realm) that you want to delete.
These instructions and examples do not include information for parameters that will be emptied for configurations that will otherwise be left intact. This information will appear in the following form: <attribute> <attribute value> removed from <object name/configuration name> with key <key value>.
To delete a specific realm and its associated configurations:
