Archive Commands
Creating Archives
You can create archives of log files. Creating log archives requires a unique procedure described below.
File Locations
The following table lists source and destination directories used with archive functions.
| Configuration Type | Source Directory | Destination Directory |
| Log | /opt/logs | /opt/archives |
Viewing Free Space
The check-space-remaining command checks the free space in the boot directory, code (flash memory), and other devices. Type a ? at the command to see all valid values. This command displays the total number of bytes free and total number of bytes available on the specified device. Each volume is used in the following way:
- /boot—A flash memory partition used primarily for system boot images and the bootloader image.
- /code—A flash memory partition used to store archives and data that needs to be persistent across reboot.
