Backup Commands
The Oracle Communications Session Border Controller includes a set of commands for easily working with backup configurations. These commands are backup-config, display-backups, delete-backup-config, restore-backup-config.
Oracle suggests that you back up properly functioning configurations on your system before making any new major configuration changes. The backup configurations are crucial to have when configuration changes do not function as anticipated and a rollback must be applied immediately.
To back up the system configuration, use the backup-config command. You can confirm your backup has been created with the display-backups command. When the backup-config command is executed, the system checks if sufficient resources exist to complete the operation. If resources are sufficient, the system creates the backup. If resources are insufficient, the task is not completed and the Oracle Communications Session Border Controller instead displays the limiting resources, recommending that the task be completed at another time.
Backups are created as gzipped files in a .gz format. They are stored in the /code/bkups directory on the Oracle Communications Session Border Controller.
