Session Agent Ping Message Formatting
You can configure the user portions of the Request-URI and To: headers that define the destination of a session agent ping message, and the From: header that defines the source of a session agent ping message. These headers are sent to Oracle® Enterprise Session Border Controller session agent. This feature is required for interoperability with certain E911 servers.
In the following example of a session agent ping-type message, you can set the user portion of the Request-URI (the text bob in the OPTIONS method line) and the user portion of the From: header (the text bob in the From: header) to the same new value. You can also set the user portion of the To: header (the text anna in the To: header) to its own new value.
OPTIONS sip:bob@sip.com SIP/2.0 From: UA1 <sip:bob@sip.com> To: NUT <sip:anna@gw.sip.com> Call-ID: 123abc@desk.sip.com CSeq: 1 OPTIONS Contact: <sip:UA1@client.sip.com> Accept: application/sdp Content-Length: 0
If you do not enable this feature, then the session agent ping-type message contains the text ping in all cases.
