Session Agent Ping Message Formatting Configuration
Access the
session-agent configuration element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# session-agent ORACLE(session-agent)
Select the
session-agent object to edit.
ORACLE(session-agent)# select <hostname>: 1: 192.168.100.101:1813 selection: 1 ORACLE(session-agent)#
ping-from-user-part—Set the user portion of the From: header that defines the source of a session agent ping message.
ORACLE(session-agent)# ping-from-user-part bob
ping-to-user-part—Set the user portions of the Request-URI and To: headers that define the destination of a session agent ping message.
ORACLE(session-agent)# ping-to-user-part anna
- Type done to save your configuration.
