SNMP MIBs and Traps Related to VNF Deployments
The following MIBs and traps are supported for the Oracle® Enterprise Session Border Controller. Please consult the MIB Reference Guide for more SNMP information.
apUsbcSysDPDKObjects
This group of
objects, found in the
ap-usbcsys.mib,
provide a listing of DPDK statistics.
| MIB Object | Object ID: 1.3.6.1.4.1.9148.3.17.1.1.13 + | Description |
| apUsbcSysDPDKFwdPurpose | .1 | A bitset representing Forwarding cores. 1s represent forwarding cores, while 0s represent non-forwarding cores. |
| apUsbcSysDPDKDOSPurpose | .2 | A bitset representing DoS cores. Bits set to 1 represent DoS cores, while 0s represent non-DoS cores. |
| apUsbcSysDPDKSigPurpose | .3 | A bitset representing signaling cores. Bits set to 1 represent signaling cores, while 0s represent non-signaling cores. |
| apUsbcSysDPDKTransPurpose | .4 | A bitset representing transcoding Cores. Bits set to 1 represent transcoding cores, while 0s represent non-transcoding cores. |
| apUsbcSysDPDKCmdLine | .5 | System CmdLine string - as defined in /proc/cmdline. (including relevant bootparams.) |
| apUsbcSysDPDKFileMem | .6 | Total DPDK File Memory. |
| apUsbcSysDPDKSysMem | .7 | Total DPDK System Memory |
| apUsbcSysDPDKNum1G | .8 | Number of 1GB Hugepages allocated. |
| apUsbcSysDPDKNum2MB | .9 | Number of 2MB hugepages allocated. |
| apUsbcSysDPDKHypervisorType | .10 | The description regarding the system type and what hypervisor the system is running on (OVM, KVM, VMWare,...). |
| apUsbcSysDPDKAddFwdCores | .11 | Number of additional cores that may be used for forwarding. |
| apUsbcSysDPDKAddSigCores | .12 | Number of additional cores that may be used for signaling. |
| apUsbcSysDPDKAddTransCores | .13 | Number of additional cores that may be used for transcoding. |
apUsbcSysScalingObjects
This group of
ap-usbcsys.mib,
provide a listing of objects relating to scaling VMs.
| MIB Object | Object ID: 1.3.6.1.4.1.9148.3.17.1.1.12+ | Description |
| apUsbcSysEstSessions | .1 | Estimated number of unecrypted media sessions. |
| apUsbcSysEstG711G729Trans | .2 | Estimated number of G711<->G729 transcoded media sessions. |
| apUsbcSysEstSigTPS | .3 | Estimated number of signaling TPS. |
| apUsbcSysEstACLs | .4 | Estimated number of ACLs. |
| apUsbcSysEstTCP | .5 | Estimated number of TCP connections. |
| apUsbcSysEstTLS | .6 | Estimated number of TLS connections. |
| apUsbcSysEstVLANs | .7 | Estimated number of VLANs. |
