Show Commands Related to VNF Deployments
show datapath-config
This command displays the current DPDK-based settings for the datapath. The command has no arguments.
Syntax
Output Example
As shown below, this command displays key core and memory configuration of the deployment. Exact output is dependent on your environment.
For example, you may or may not be using hyperthreading, which establishes physical vs. logical CPU considerations. Some hypervisors do not present physical and logical cores such that the SBC can differentiate between CPU types using uppercase and lowercase letters. In these conditions, the SBC displays all CPUs with uppercase letters. When supported by the platform, however, the SBC displays a second logical core of each physical core using lowercase lettering.
Bear in mind that the second, logical core of a physical core cannot be assigned to any DPDK function. The system automatically sets them to signaling.
A VM with 8 vCPUs and hyper-threading enabled assigns the pairing of the cores as follows:
- Cores (0,4)
- Cores (1,5)
- Cores (2,6)
- Cores (3,7)
NFV-1# show datapath-config
Number of cores assigned to VM: 8
Current core assignment: S-F-D-X-s-s-s-s
Requested Page size: 1 GB
Current Page size: 2 MB
Number of 1 GB pages: 0
Number of 2 MB pages: 10
Total system memory: 3841 MB
Memory reserved for datapath: 1020 MB
Memory requested for datapath: 2048 MB
| Field | Description |
| Number of cores assigned to VM | The number of cores that this VM can use. |
| Current core assignment | The core assignment, based on function
type:
The position of the function indicates the core number. |
| Requested Page size | Configured page size. |
| Current Page size | Actual page size. |
| Number of 1 GB pages | Number of 1GB Hugepages allocated. |
| Number of 2 MB pages | Number of 1GB Hugepages allocated. |
| Total system memory | Total DPDK System Memory. |
| Memory reserved for datapath | Actual memory reserved for datapath. |
| Memory requested for datapath | Configured memory reserved for datapath. |
show platform limits
This command displays the current limits for a variety of operating capacities. The output of show platform limits is based on the platform this command is executed from and the software version running. The command has no arguments.
Syntax
Sample output is displayed below.
ORACLE# show platform limits
Maximum number of sessions:3000
Maximum number of ACLS: 60000
Maximum number of common PAC buffers: 8000
Maximum number of kernel-rules: 216256
Maximum CPS rate: 300
Maximum number of TCP Connections: 60000
Maximum number of TLS Connections: 10
Maximum number of packet buffers: 30000
Maximum Signaling rate: 4000
Maximum number of session agents: 125
Maximum number of System ACLs: 256
Maximum number of VLANs: 4096
Maximum number of ARPs: 4104
Maximum number of INTFC Flows: 4096
Maximum number of Static Trusted Entries: 8192
Maximum number of Untrusted Entries: 4096
Maximum number of Media Entries: 6000
Maximum number of Deny Entries: 8192
Maximum number of Internal Flows: 32
Maximum number of Sip Rec Sessions: 512
Maximum number of RFC 2833 Flows: 6000
Maximum number of SRTP Sessions: 500
Maximum number of QoS Sessions: 3000
Maximum number of Xcoded Sessions: 100
Maximum number of HMU Flows: 6000
Maximum number of Transport Sessions: 0
Maximum number of MSRP Sessions: 0
Maximum number of SLB Tunnels: 0
Maximum number of SLB Endpoints: 0
Maximum number of IPSec SAs: 0
Maximum Licensed Capacity: 256000
