Use the ACLI
select command so that you can work with the enforcement profile configuration to which you want to add this parameter.
ORACLE(enforcement-profile) select
sdp-address-check—Enable or disable SDP address checking on the
Oracle® Enterprise Session Border Controller. The default for this parameter is
disabled.
If a mismatch occurs and you want to reject the call with a status code other than 488, you set the code you want to use in the local response code map entries.
