SIP SDP Address Correlation Configuration Mismatch Status Code
To apply a new status code to a SDP address correlation mismatch:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
local-response-map and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# local-response-map ORACLE(local-response-map)#
Type
entries and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(local-response-map)# entries ORACLE(local-response-map-entry)#
From here, you can view the entire menu for the local response map entries configuration by typing a ?.
- local-error—Enter sdp-address-mismatch for which to apply the new status code.
- sip-status—Set the SIP response code to use.
sip-reason—Set the SIP reason string you want to use for this mapping.
ACMEPACKET(local-response-map-entry)# local-error sdp-addressmismatch ACMEPACKET(local-response-map-entry)# sip-status 403 ACMEPACKET(local-response-map-entry)# sip-reason sdp address mismatch
- Save and activate your configuration.
