Timer to Tear Down Long Duration Calls
The Oracle® Enterprise Session Border Controller currently provides the “flow-time-limit” timer to terminate long duration calls. However, this timer is reset whenever the Oracle® Enterprise Session Border Controller receives a Re-INVITE or UPDATE message, even when it is provided for the session timer. This feature adds a non-resettable timer that, when enabled and upon expiration, tears down long duration calls.
When the “flow-time-limit” timer for terminating long media flow expires, the Oracle® Enterprise Session Border Controller sends a SIP BYE or H323 Release Complete message to tear down the long call. However, this timer is reset whenever the SBC receives a Re-INVITE or UPDATE message. In most call scenarios, long duration calls are terminated with the expiration of this timer, but there are some cases where a call can stay connected for a longer duration. For example, if a user connects to an IVR service and does not hang up the phone receiver properly, there is no way for the network provider to free up the IVR resources if the user devices send session updating requests. To prevent this situation, this feature adds a new timer session-max-life-limit, which starts when the call or session is established and does not reset for any session update, keep-alive or SBC switchover. On expiry, the call is torn down if it’s in established state.
The new timer session-max-life-limit can be provisioned in the following configuration elements, in order of precedence from highest to lowest: session-agent, realm-config, sip-interface, and sip-config. Its range of values is {0-2073600} seconds with an additional special case value of “Unlimited”, which is treated as the highest possible value. The default value is 0 (no timer).
Difference between 0 and Unlimited
No timer is created when session-max-life-limit is configured to either the value 0 or “Unlimited”, so no timeout can occur. The difference between the two values is how they are handled when determining which value of session-max-life-limit to use when there are several specified within the various configuration elements. When a session is created the timer examines both the ingress side and the egress side and, in cases where both sides have a configured value for session-max-life-limit, uses the side with the lower (stricter) value. On each side, the SBC reviews the configuration elements relevant to the session and uses the value of session-max-life-limit from the configuration element with the highest precedence (session-agent, then realm-config, then sip-interface, and lastlysip-config). When the value is set to 0, the configuration element is ignored and the next configuration element in the precedence chain is looked at. A value between 1 and 2073600 (24 days) or the value “Unlimited” is treated as a valid configured value. In this case the SBC will not move onto the next element in the precedence chain and the value is used in the final comparison between the egress and ingress values. The value “Unlimited” is viewed as the highest possible value, and therefore is considered greater than any other value it is compared against. The value 0 is skipped over and completely ignored.
For example, on the ingress side the value of session-max-life-limit in realm-config is set to 86400 and the value of session-max-life-limit in session-agent is set to "Unlimited". The session-agent value has a higher precedence than the realm-config value so, therefore, the value “Unlimited” is used for the ingress side. On the egress side the value of session-max-life-limit in realm-config is set to 43200 and the value of session-max-life-limit in session-agent is set to 0 (no timer), so the value of session-max-life-limit in realm-config is used. When compared against the ingress side the value 43200 is less than “Unlimited”; therefore, the value set for the timer is 43200.
