Timer to Tear Down Long Duration Calls Configuration
Use the following procedure to configure, in the session-agent, realm-config, sip-interface, and sip-config configuration elements, a non-resettable timer that, when enabled and upon expiration, tears down long duration calls.
Although the timer occurs in four separate configuration elements, for brevity only the procedure for configuring
realm-config is shown as the general procedure does not vary for the other configuration elements.
For the
realm-config configuration element:
