The show command that appears for each ACLI configuration element allows you to view the configured information for a given element. The following example shows how to view media-profile configuration summaries.
To view the settings for the media-profile element:
Enter the media-profile configuration element through the ACLI path.
ORACLE# configure terminal
ORACLE(configure)# session-router
ORACLE(session-router)# media-profile
ORACLE(media-profile)#
From media-profile, use the select command. The
<name>: prompt and a list of configured media-profile elements appear.
ORACLE(media-profile)# select
<name>:
1: PCMU
2: G723
3: G729
Select the configured media profile you want to view by entering the corresponding number and press the <Enter> key.
Type
show and press the <Enter> key.
ORACLE(media-profile)# show
media-profile
name PCMU
subname
media-type audio
payload-type
transport RTP/AVP
req-bandwidth 0
frames-per-packet 0
parameters
average-rate-limit 0
peak-rate-limit 0
max-burst-size 0
sdp-rate-limit-headroom 0
sdp-bandwidth disabled
police-rate 0
standard-pkt-rate 0
last-modified-by
last-modified-date
