Direct Inward Dial (DID)-Range-Based Local Routing Table (LRT)
The Oracle® Enterprise Session Border Controllersupports LRT, an XML document that contains either E164 telephone numbers or strings-to-SIP-URI mappings. An iLRT is is configured and transferred from the development environment to the ESD /code/lrt directory. After installation and configuration, the LRT is available for SIP Request routing.
The information in the following sections is specific to contiguous ranges of Direct Inward Dial (DID) telephone numbers. Users of this LRT type should be acquainted with XML, and familiarize themselves with the more generic LRT descriptions supplied by the SC6.4.0 ACLI Configuration Guide.
Create a DID-Range-Based LRT File
A DID-Range-Based LRT file is a well-formed XML document with a <localRoutes/> root element.
The following attribute is found within the <localRoutes/> element.
type — This attribute is required for a DID-range-based LRT; set this attribute’s value to range.
<localRoutes/> can contain any number of child <route/> elements.
Each <route/> element contains:
- a required <user/> element that (1) defines the LRT type, and (2) for a DID-range-based LRT, specifies a contiguous range of DID telephone numbers
The <user/> element contains the following attributes:
type — This required attribute can be assigned one of three enumerated values (E164, string, or range); for a DID-range-based LRT, you must use the range value.
rangeStart — This required attribute specifies the start value for the DID range.
rangeEnd— This required attribute specifies the end value for the DID range.
rangePrefix — This optional attribute specifies the common prefix for the range bracketed by the rangeStart and rangeEnd attributes.
- a required <next/> element that uses regular expression syntax to specify the routing next hop
- an optional <description/> element that provides information relevant to the range of DID addresses
When creating the LRT file, keep the following rules in mind.
Configuring a DID-Range-Based LRT
The following procedures provide information about configuring the LRT location and enabling LRT.
Managing LRT using the Show LRT Command
Existing ACLI show commands (show lrt and show lrt route-entry) commands have been enhanced to support DID ranges. A new command (show lrt route-table) displays the contents of a DID-range-based LRT.
show lrt now provides a count of valid and invalid route ranges as shown below.
ESD01# show lrt
14:43:03-64183
Local Route Statistics ---- Lifetime ----
Recent Total PerMax
Queries 0 0 0
Result - Success 0 0 0
Result - Not found 0 0 0
Valid Route Entries: 19
Invalid Route Entries: 0
Valid Route Ranges 15 // New to Version E-C[xz]6.4.0
Invalid Route Ranges 3 // New to Version E-C[xz]6.4.0
show lrt route-entry displays matching DID ranges as follows.
ESD01# show lrt route-entry lroute 323
UserName <320-329>
Entry Type = range
NextHop = !^.*$!sip:3@public-range!
NextHop Type = regexp
Description = Test DID range
The new show lrt route-table displays a DID-range-based table as follows.
ESD01# show lrt route-table la 2
UserName <320-329>
Entry Type = range
UserName <3123 - 3125>
Entry Type = range
NextHop = !^.*$!sip:1@public-range!
Displaying 2 of 13 routes. Continue [y/n]?
