Search for a Report Record
The Search button at the top of the report page allows you to find a specific record within a Monitor and Trace report. It also allows you to specify criteria on which to perform the search.
You can specify a value for any or all of the fields in the Search box. The search process searches for records with all of the values you specify and displays only the records with these values. If you perform a Global Search and specify values in other fields, the search process searches the other specified fields first and then filters on the Global Search field.
  • If you specify a “*” in a search string, the search is performed on that exact string. For example, if you search for “123*45”, the search shows results for all strings containing “123*45”.
  • You can use quotes (“ “) to specify a search. For example, you can enter Smith and the search finds all of the records that match Smith, such as: John Smithfield<sip:sipp@192.168.1.70:5070>;tag=12260SIPpTag001.
  • If you enter a space before or after a quotation mark, (for example, “Smith “), the search returns no data.
  1. On any reports page, click Search and do the following in the Search Filter dialog.
  2. Click Search.
