Export Information to a Text File
Monitor and Trace allows you to export information to a text file from the Sessions, Registrations, Subscriptions and Notable Events Reports, as well as from a specific ladder diagram, or from a page containing the results of a search. The system exports data to a file that you can open and view as required.
You can export any of the following:
- All information from each report
- Information from a specific record only
- Information from a search result
- Information from a Ladder Diagram
The following list identifies the buttons to use to export specific information from Monitor and Trace. All the export buttons in the GUI export to text files.
Exports the SIP messages and media events associated with the selected session, to a file in text format on the local machine. |
Exports all logged session summary
records to a file in text format on the local machine.
Note: This button exports ALL call session summary records or the records that matched a search criteria to the file. |
Exports all of the information in the Ladder Diagram (Session Summary, SIP Message Details, and QoS statistics), to an HTML file format on the local machine. |
Exports detailed information about the SIP messages and media events in the Ladder Diagram associated with the selected session, to a file in text format on the local machine. |
