Widgets Tab
The Widgets tab contains a list of all available widgets that you can use to view system data and statistics.
When you click the name of a Widget in either the navigation pane or the All Widgets list, the system displays the widget in full-screen mode. If you view a certain widget frequently, you might want to add it to the Favorite Widgets list on the Widgets page or add it to the Dashboard on the Home page. You can perform both tasks from the widget with the icons displayed in the upper right corner of the widget.
