Configuration Tab
The Configuration tab on the Web GUI provides a graphical display of the same objects and elements that you can access from the command line to configure the Oracle® Enterprise Session Border Controller (E-SBC).
The Web GUI provides the following configuration tools.
- Basic Mode. Displays a workspace where you drag-and-drop icons representing network objects and system elements, so that you can see a graphical representation as you build the network. When you click an icon on the workspace, the Web GUI displays the corresponding configuration dialog.
 - Expert Mode. Displays a list of the network objects and system elements. When you click an element on the list, the Web GUI displays the corresponding configuration dialog. In Expert Mode, the system does not display the workspace and graphical representation of the network as it does in Basic Mode.
 - Wizards. Displays a menu of select configuration wizards that lead you through setting boot parameters, setting entitlements, setting the initial configuration, setting the license, setting the logon banner text, setting the time zone, and upgrading the software.
