View Any Widget in Full-Screen Mode Use the Widgets tab to display data from the SIP and System Dashboard widgets in full-screen mode. Use the following procedure to view widgets that are not displayed on the Home page as Dashboard widgets, in full-screen mode. From the Web GUI, click the Widgets tab. In the navigation pane, click a Dashboard Widget name. The system displays a list of the views available for the selected widget. In the list of view types click the view that you want to see in full-screen.
