PreviousNextJavaScript must be enabled to correctly display this content
Add a Widget to Favorites
If you view a widget often, you may want to add it to the Favorites list on the Widgets tab.
When you select a widget to add to Favorites, the system displays an icon of a push-pin on the tool bar at the top of the widget. Use the push-pin icon to add the widget to Favorites.
From the Web GUI Home page, click the Widgets tab.
From the All Widgets list, click the widget that you want to add to Favorites.
The system displays the widget.
From the displayed widget, click the "Add the view to the favorites" icon. (Top, right. Shaped like a push-pin.)
