Upgrade Software
You can upgrade the system software from the System tab. The system requires a reboot after the upgrade.
- From the Web GUI, click System, Upgrade software.
In the Upgrade
Software dialog, click
Verification, and do
the following:
- View the health score.
- Click View Health Information, and confirm that the system components are synchronized.
- Click View Configuration Version, and note the Current Version and Running Version.
- Click View Disk Usage, and confirm that the system has enough free space.
Select one of the
following upload methods.
Local Select a file from your system, and proceed to Step 4 Flash Select a file already on the device, and proceed to Step 4. Network Do the following: - Boot file. (Network) Enter the complete name of the boot file.
- Host IP. (Network) Enter the IP address of the FTP server.
- FTP username. (Network) Enter the user name to log onto the FTP server.
- FTP password. (Network) Enter the password to log onto the FTP server.
- Optional. Select
Reboot after upload.
Proceed to Step 6.
- Select a file to upload.
(Optional) Select
Reboot after upload. -
Click
Complete.- If you did not select
Reboot after upload, the system displays a message stating that a reboot is required for the changes to take effect. - If you selected
Reboot after upload, the system displays a message stating that it is about to reboot.
Click
OK.If you selectedReboot after upload, the system reboots.
