PreviousNextJavaScript must be enabled to correctly display this content
Obtain Support Information
You can manually generate a predefined file by way of the Web GUI that contains troubleshooting information. You can save the file and send it to Oracle Customer Support.
From the Web GUI, click the
System tab.
On the System page, in the navigation pane, click
Support Information.
On the Support information page, click
