System Reboot
You can manually reboot the Oracle® Enterprise Session Border Controller (E-SBC) from the Web GUI. Note that when you reboot the system from the Web GUI, the Web GUI is unavailable until the reboot is complete. If you have a High Availability (HA) deployment, connectivity to the secondary E-SBC stops until the reboot is complete.
When the reboot is complete, the primary and secondary systems each display the logon screen. You must manually log on to each system.
| When you perform a reboot from the Web GUI | The system behaves |
| and no boot is in process and the system is not failing over to the secondary system in an HA environment | the GUI session closes and the system displays the Logon screen. You cannot log on to the Web GUI until the reboot is complete on the E-SBC. |
| and a reboot is already in progress | the system displays a message indicating that a reboot cannot occur. The first reboot must complete before another reboot is initiated. |
| and the primary system is currently failing over to the secondary system in an HA environment | the system displays a message indicating that a reboot cannot occur. The HA switch over is underway. The secondary E-SBC is updating and getting its configuration from the primary E-SBC. |
