Expert Mode Tools
Use the following tools to create the configuration in Expert Mode.
Use to verify and save the current
configuration in Expert Mode. A prompt also displays giving you a choice of
whether or not to activate the configuration.
Note: After clicking Save, a notification icon in the upper right corner of the screen indicates the configuration still needs to be activated. You can continue to make changes to the configuration as required. When finished, you can select Notifications, Save changes to save and activate the configuration. The notification icon dims after saving and activating. |
The system displays notifications and alarms. |
Use to a list of configuration wizards and the Update Software wizard. |
Use to perform a search of any configuration element or sub-element on the Oracle® Enterprise Session Border Controller. You perform the search by entering a keyword which is not case sensitive. Special characters are allowed. |
Allows you to discard all configuration changes made in the current session. Only the changes that have not yet been activated are discarded. |
Use to switch from Expert Mode to
Basic Mode.
Note: If you save your configuration in Expert Mode, you cannot switch to Basic Mode. Caution: You can switch to Basic Mode from Expert Mode, if you do not save your changes. If you save your changes and you switch back to Basic Mode, you must run the Set Initial Configuration wizard again. You will lose all of the configuration changes you made in both modes. |
Use to display advanced parameters, which the system displays in italics. Is active only in configuration dialogs that contain advanced parameters. |
Use to hide advanced parameters from view. Is active only in configuration dialogs that contain advanced parameters. |
Use to display the sub-objects
related to a configuration element in Expert mode. A configuration element that
contains sub-objects displays the
Show configuration button on the corresponding Edit configuration dialog. |
Function Buttons
Expert Mode displays function buttons on each configuration page to perform tasks such as add, edit, copy, and delete. The system activates the buttons depending on your selection on a page. Some sub-element tables also display these buttons. The following table describes each button.
| Add | Use to add configuration information to the Oracle® Enterprise Session Border Controller. |
| Edit | Use to edit existing configuration information.
Note: Select an item in a list to enable the Edit button. |
| Clear | Use to clear the Search field. |
| Copy | Use to copy existing configuration information, and
edit the information to create a new configuration.
Note: Select an item in a list to enable the Copy button. |
| Delete | Use to delete a single entry from a list.
Note: Select an item in a list to enable the Delete button. |
| Delete All | Use to delete all instances in the top-level object of a multi-instance object. |
| Download | Use to save and download a configuration file in the .csv format. Displays only in a multi-instance object. |
| Search | Use to search for configured objects. |
| Upload | Use to upload a .csv file. Displays only in a multi-instance object. |
