39System Preferences
System Preferences
This chapter lists some system preferences in your Siebel Business Applications. It includes the following topic: System Preferences for Siebel Business Applications.
The following table includes some system preferences for Siebel Business Applications. For information about how to change system preferences, see Setting System Preferences.
Table System Preferences
| Preference | Description |
ActivationLoadBalancerConfig |
Set this preference to the Configuration ID for the load splitter configuration that you want to use for activating territory alignments. For use with the Assignment Manager’s load splitter. For more information about load splitter, see Siebel Assignment Manager Administration Guide. For more information about activating territory alignments, see Siebel Territory Management Guide. |
Activity Hierarchy: Max Levels |
Specifies the maximum number of levels for the Activity Hierarchy. |
Alarm Manager Load Frequency |
Specifies the number of minutes the Siebel application waits before rechecking for alarms. The default value is 60. |
AllowOverReceipts |
If this preference is set to TRUE, then the received quantity can be greater than the shipped quantity. Also, for an internal order, when the Process Receipt command is invoked, the pick ticket can be closed only when the received quantity is equal to or greater than the shipped quantity. For more information about shipping and receiving, see Siebel Field Service Guide. |
Always Show Message Bar Alerts |
Obsolete. |
Allow Non Owner Modify Calendar |
If this preference is set to TRUE, a non-owner can edit the Calendar event. If the preference is set to FALSE, a non-owner cannot edit the Calendar event. |
Asgn:Inherit Org Candidates |
If this preference is set to TRUE, then the organization candidates on an assignment rule can be copied to rules that inherit from the assignment rule. After the rule is inherited, any change to the organization candidate of the original rule has no effect on the inherited rule. |
Auto Mgr Calendar Access |
Permits the employee’s manager access to the employee’s calendar, even if the employee does not explicitly give the manager access. The default value is True. |
Calendar Team Primary |
Determines the employee calendars that an employee manager can access. This preference applies only if you set the Auto Mgr Calendar Access preference to True. A value of True indicates the manager can access the calendars of only the employees who are primary employees in the position hierarchy of the manager. A value of False indicates the manager can access the calendars of all employees in the position hierarchy of the manager. |
CSM Logging |
Enables logging of merge transactions. Merge transactions are created when connected users combine or merge two or more business components, such as accounts or opportunities, into one business component. Information from this log can be used to relink orphaned records created when the merge process is crossed with an update process during a synchronization. This preference is applicable only if the installation uses Siebel Remote or Replication Manager. The default value is False. |
DB2: Default Opt Level |
Specifies the default optimization level which defines the optimizing algorithm that DB2 uses to execute SQL statements. |
DBX: Vis Rules per Statement 1 |
Specifies the number of visibility or routing rules checked for each SQL statement processed by the Database Extract component for the first SQL statement with header information. |
DBX: Vis Rules per Statement N |
Specifies the number of visibility or routing rules checked for each SQL statement processed by the Database Extract component for other SQL statements. |
Default Campaign Source Code |
Specifies the default campaign for Web offers used in Siebel Marketing. All offers that are a part of the default campaign appear in the Featured Offers applet in Siebel Marketing. |
Default EC Procedure |
Obsolete. |
Default Offer Code |
Specifies the code to track the click path of a customer on the Marketing Web site who does not select a specific offer. |
Default Pricing Procedure |
Obsolete. |
Default Time Zone |
Specifies the default time zone for all users of the Siebel database. When a user logs in, the Time Zone field of the User business component is checked. If the field is empty, then the Default Time Zone system preference is checked. The default value is UTC. |
EnableSafeBoot |
Siebel OOTB Runtime Repository is shipped as a loadable unit (DLL/SO). When the EnableSafeBoot parameter is set to TRUE, the OOTB Runtime Repository is used. For Mobile Web Client, set this preference to TRUE along with RepositoryType. For Siebel Enterprise Server, set EnableSafeBoot as follows: change param EnableSafeBoot=TRUE for comp SCCobjMgr_enu For more information, see Configuring Siebel Business Applications. |
Enable UPT |
For more information, see Usage Pattern Tracking |
Enable ST Script Engine |
Set this preference to TRUE to enable the Strong Typing (ST) eScript engine. Siebel eScript is a scripting language that application developers use to write simple scripts to extend Siebel Business Applications. The Strong Typing eScript engine provides improved performance, scalability, and enhanced functionality when running scripts. For more information about the ST eScript engine, see Using Siebel Tools. |
EnableAuditing |
For more information, see Siebel Audit Trail |
EnableEimAuditing |
Entitlement: Pricing Dates |
If this preference is set to False or NULL, then date verification is skipped when entitlement pricing terms are checked in the Verify Entitlement process. (This preference is similar to the Entitlement: Verify Dates system preference except that this preference applies to entitlement pricing terms and the other preference applies to entitlement service terms.) |
Entitlement: Verify Consumer |
For more information, see Siebel Field Service Guide. |
Entitlement: Verify Dates |
Entitlement: Verify Product |
ETL Analysis End ETL Analysis Start ETL Date Format |
ETL Date format specifies the way dates are interpreted. The other two preferences specify the date range for which the Exchange Rates are adjusted. This range does not indicate that only the data created within this range is extracted. Select the earliest date for the Analysis Start Date (when the transactions might have begun). In addition to considering the created and modified dates, consider other relevant dates such as order date. Setting this date to an early value such as 19700101 (January 1, 1970) does not affect the processing time. A similar logic applies for choosing Analysis End Date. Enter the values in the format defined by ETL Date Format. The default Analysis End value is 20101231. The default Analysis Start value is 19940101. The default Date Format value is YYYYMMDD. |
ETL Base Exchange Currency |
Specifies the currency in which all the financial data is converted. While the OLTP supports transactions in many different currencies, the data in the OLAP is converted to a single currency for analysis purposes. The Exchange rates are derived from the Exchange Rates table in the OLTP. The default value is USD. |
ETL Default Continent |
Specifies the value for any address that does not have Continent defined. Set this preference to a value, which is used if the value of Continent is not defined in the OLTP. The default value is North America. |
ETL Default Country |
Specifies the value for any address that does not have the Country defined. Set this preference to a value, which is used if the value of Country is not defined in the OLTP. The default value is USA. |
ETL Default Currency |
Specifies the value for currency code that is used if the currency code for a specific financial transaction is not set. The default value is USA. |
ETL Default Language |
Specifies the language code used when language translation occurs when looking up the List of Values table. The default value is ENU. |
ETL LOV Maximum Value ETL LOV Minimum Value |
Set these preferences to the maximum and minimum values for bucketing of fields. Instead of indicating the number of employees at an account is 45, 96, the values can be bucketed to 0-50, 50-100 and so on. In the List of Values, if the minimum and maximum values are not specified, then the values of these preferences are used. The default values are 9999999999 and 0. |
ETL Unknown Exchange Rate |
Specifies the value used when an exchange rate for a currency to the Datamart Default Currency is undefined in the OLTP. The default value is 1. |
Forecast: Auto-Forecast |
Creates subordinates’ forecasts to be used in a rollup forecast, if the subordinates have not created forecasts themselves. |
Forecast: Use Server Task |
Sends forecast processing requests to the Siebel Server for batch processing. If the value is False, then requests are processed locally. |
FSAssetSwap SubComponents |
If this preference is set to TRUE, then the subcomponent assets of the source asset are shifted to the target asset when an activity part tracker transaction is committed. |
FSDB:Override Service Region |
Specifies the maximum monetary value accepted in Auction Item, Bid, and Fee currency fields. |
Internal DUNS Number |
Specifies your company’s DUNS number. |
LOGMGR:Vis Rules per Statement |
Set this preference to 20 for implementation that use any database other than Oracle. The default value is 50. |
MRG:Docking Timestamp Source |
For more information, see Siebel Remote and Replication Manager Administration Guide. |
MRG:Inter Table Conflict Res |
MRG:Inter Table Merge Rule |
MRG:System Conflict Resolution |
MRG:Txns per Commit |
MRG:User Friendly Notification |
PSP Pricing Var Map - Context |
For more information, see Siebel Pricing Administration Guide. |
PSP Pricing Var Map - Row Set |
PSP Pricing Var Map - XA |
ProposalReportSleepTime |
Set this preference to lengthen the time to write the records so that all of the records are included in the report. If a report in a section of a proposal contains a large number of records, then the document server can stop the srviewer before all of the records are written to the resulting HTML file. |
Quick Print Application |
Determines which application is used by quick print. Allowed values are HTML and EXCEL. This preference can be overridden by the Quick Print Application user preference. |
Quick Print Output Format |
Set this preference to HTML, CSV, or Tab, as appropriate for the quick print application that you are using. |
RepositoryType |
Siebel OOTB Runtime Repository is shipped as a loadable unit (DLL/SO). When the EnableSafeBoot parameter is set to TRUE, the OOTB Runtime Repository is used. For Mobile Web Client, set RepositoryType to RUNTIME along with EnableSafeBoot. For more information, see Configuring Siebel Business Applications. |
RunAlignmentLoadBalancer Config |
Set this preference to the Configuration ID for the load splitter configuration that you want to use for running territory alignments. For use with the Assignment Manager’s load splitter. For more information about load splitter, see Siebel Assignment Manager Administration Guide. For more information about running territory alignments, see Siebel Territory Management Guide. |
SalesHierarchy:UseServerTask |
If this preference is set to TRUE, then the Sales Hierarchy operation runs as a server task. |
Satmetrix Key Value |
Specifies a string provided by Satmetrix to customers of Siebel Satmetrix Surveys. Required for generating encrypted tokens that are part of URLs for displaying survey reports. |
Sch:Break Time Id |
Specifies the Row ID of the work type to be used when calculating the schedule cost where activities contain breaks. The default value is -1. To find the Row ID, navigate to the Administration - Data screen, then the Work Type view, select the record, select Help from the application-level menu, select About Record, and note the value for the row number. |
Sch:Default Constraint Set |
Specifies the Row ID of the constraint set to be used where no constraint set is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen, then the Constraint Sets view, select the record, select Help from the application-level menu, select About Record, and note the value for the row number. |
Sch:Default Cost Function |
Specifies the Row ID of the cost function to be used where no cost function is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen, then the Cost Functions view, select the record, select Help from the application-level menu, select About Record, and note the value for the row number. |
Sch:Default Parameter Set |
Specifies the Row ID of the parameter set to be used where no cost function is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen, then the Parameter Sets view, select the record, select Help from the application-level menu, select About Record, and note the value for the row number. |
Sch:Default Time Window |
Specifies the Row ID of the time window to be used where no cost function is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen, then the Time Window view, select the record, select Help from the application-level menu, select About Record, and note the value for the row number. |
SecThickClientExtAuthent |
For more information, see Siebel Security Guide. |
SM WebIntelligence Server |
Specifies the URL that points to the Web Intelligence server that serves up reports for Oracle Business Intelligence. |
SqlStyle |
Specifies the SQL statements to use with this implementation (Oracle, Microsoft SQL Server, Informix, or Sybase). Case-sensitive. |
SSASqlErrRsltsDiscarded |
Specifies the message that appears to the user when there are more rows than can be returned. For more information, see Implementing Siebel Business Applications on DB2 for z/OS. |
Strict Date Format |
Set this preference to the date format that you require to implement a strict date format. For example, to implement DD/MMM/YYYY date format, enter DD/MMM/YYYY. When you implement a strict date format, users can enter dates only in a format you specify, and all dates appear in this format. |
SubSqlStyle |
Specifies an SQLStyle that falls within a family of similar database products. |
Technical Support (Alt. 1) |
Specifies the telephone numbers to appear in the Siebel Technical Support dialog box. Update this number to match your internal help desk number. The alternate numbers (Alt. 1 and Alt. 2) provide expansion for pager numbers and email addresses. Set the value to None to leave it blank in the dialog box. |
Technical Support (Alt. 2) |
Technical Support (FAX) |
Specifies the fax number to appear in the Siebel Technical Support dialog box. Update this number to match your internal help desk fax number. Set the value to None to leave it blank in the dialog box. |
Technical Support (URL) |
Specifies the support URL to appear in the Siebel Technical Support dialog box. Update this URL to match your internal help desk Web address. Set the value to None to leave it blank in the dialog box. |
Technical Support (Voice) |
Specifies the voice number to appear in the Siebel Technical Support dialog box. Update this number to match your internal help desk number. Set the value to None to leave it blank in the dialog box. |
Time Slice Report Format |
For more information, see Siebel Product Administration Guide. |
Universal Time Coordinated |
Enables global time zone support for the entire Siebel application. Set this preference to TRUE to enable global time zone support. The default setting is TRUE.
Note: This setting is a one-time setting. After you enable global time zone support in a production environment, do not disable it.
If you intend to operate your deployment with the Global Time Zone feature enabled, then you must also set the operating system of your database servers to UTC time, or its equivalent. Although enabling this feature is optional, it is strongly recommended that you operate your production environment with Global Time Zone enabled. For more information about enabling Global Time Zone, see Siebel Global Deployment Guide. |
UPT Max Record Count |
For more information, see Usage Pattern Tracking. |
User Group |
Specifies the User Group grantee for database access privileges. This preference is used in the DDL Sync step in Oracle’s Siebel Tools where the schema for the Siebel application is defined. |
