| Bookshelf Home | Contents | Index | PDF |    |
| Configuring Siebel Open UI > Reference Information for Siebel Open UI > Life Cycle Flows of User Interface Elements > Life Cycle Flows That Save RecordsThis topic describes the life cycle flows that Siebel Open UI uses to save records. Figure 42 illustrates the life cycle flow that Siebel Open UI uses to save a record if the user simultaneously presses the CTRL and S keys. The numbers in the diagram indicate the sequence that Siebel Open UI uses during this flow. The A connector connects to the flow described in Flow That Saves Records If the User Uses the Save Menu.Figure 42. Flow That Saves Records If the User Uses a Shortcut Figure 43 illustrates the life cycle flow that Siebel Open UI uses to save a record if the user clicks Menu, and then the Save Record menu item. The A connector connects to the flow described in Flow That Saves Records If the User Uses a Shortcut.Figure 43. Flow That Saves Records If the User Uses the Save Menu |
| Configuring Siebel Open UI | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
