Configuring Siebel Open UI > Reference Information for Siebel Open UI > Browser Script Compatibility > Sequence That Siebel Open UI with Custom Browser ScriptThe following pseudocode describes the sequence that Siebel Open UI uses if your deployment includes custom browser script: PM method or event calls an applet proxy method applet proxy method calls Applet_PreInvokeMethod on browser script applet proxy uses Call-Server to run applet method on Siebel Server PM runs Attach Pre Proxy binding for this applet method applet proxy calls Applet_InvokeMethod that resides in browser script PM runs Attach Post Proxy binding for this applet method For example, the following pseudocode describes the sequence that Siebel Open UI uses if the user clicks New in an applet, and if your deployment includes custom browser script that uses a method named NewRecord: PM.OnControlEvent calls Applet.InvokeMethod Applet.InvokeMethod calls BrowserScript.Applet_PreInvokeMethod Applet.InvokeMethod calls Siebel Server to run NewRecord method on applet PM calls PM.AttachPreProxyExecuteBinding for the NewRecord method Applet.InvokeMethod calls BrowserScript.Applet_InvokeMethod PM calls PM.AttachPostProxyExecuteBinding for the NewRecord method |
| Configuring Siebel Open UI | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
