| Bookshelf Home | Contents | Index | PDF |    |
| Configuring Siebel Open UI > Reference Information for Siebel Open UI > Life Cycle Flows of User Interface Elements > Life Cycle Flows That Handle User Actions in List AppletsThis topic describes the life cycle flows that Siebel Open UI uses depending on an action that the user does in a list applet. Figure 54 illustrates the flow that Siebel Open UI uses if the user navigates to another row in a list applet.Figure 54. Flow That Handles Navigation to Another Row in List Applets Figure 55 illustrates the flow that Siebel Open UI uses if the user clicks the pagination button in a list applet.Figure 55. Flow That Handles the Pagination Button in List Applets Figure 56 illustrates the flow that Siebel Open UI uses if the user sorts a column in a list applet.Figure 56. Flow That Handles a Column Sort in List Applets Figure 57 illustrates the flow that Siebel Open UI uses if the user clicks a cell in a list applet.Figure 57. Flow That Handles a Cell Click in List Applets Figure 58 illustrates the flow that Siebel Open UI uses if the user edits a cell in a list applet, and then navigates away from this cell.Figure 58. Flow That Handles a Cell Edit and Blur in List Applets Figure 59 illustrates the flow that Siebel Open UI uses if the user clicks a drilldown field in a list applet.Figure 59. Flow That Handles a Drilldown in List Applets |
| Configuring Siebel Open UI | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
