Siebel VB Language Reference > Using Siebel VB > About Data Types > Type CharactersSiebel VB can use a special character as the suffix of the name of a function, variable, or constant. This character identifies the data type of the variable or function. It is a declaration. Table 5 lists the characters you can use as a suffix. |
Siebel VB Language Reference | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
