Siebel VB Language Reference > Using Siebel VB > About Formatting Strings > Other Formatting OptionsThis topic describes other formatting options that you can use with the Set String Format method. Changing Formatting SequenceSiebel VB formats characters from first to last, by default. To format characters from last to first, you can include an exclamation point (!) in the format argument. Changing CaseSiebel VB does not modify the case of characters that it formats, by default. To instruct Siebel VB to modify the case of a character, you can use the following characters:
Handling Spaces That Occur in the Input StringTable 22 describes characters that you can use to handle spaces that occur in the input string. |
| Siebel VB Language Reference | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
