Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4213 Cmd Rej: Current set of next elog entries have been overwritten
Since the previous entry of a rtrv-log command, a number of UAMs and/or UIMs have been logged. Consequently, the pointer to the next log to display has been overwritten by those alarms occurring since the original rtrv-log command was entered. Because the pointer was overwritten by system activity, the next parameter cannot be specified until after a new rtrv-log command without a next parameter is entered and executed.
Recovery
  1. Re-enter the rtrv-log command without specifying the next parameter. Refer to the command description in Commands User's Guide for assistance.
  2. Re-enter the rtrv-log command that generated this error message, if desired.
    Contact My Oracle Support for additional assistance. See My Oracle Support (MOS).
