ISR Dashboard Database Failover
To support a high availability (HA) Index environment, the ISR Dashboard supports both primary and secondary production databases.
The Dashboard always attempts to connect to the primary Index first and the secondary database is only used when the Dashboard fails to connect to the primary database. If the Dashboard cannot connect to the secondary Index database, the ISR displays an error.
