Configuring ISR Dashboard Database High Availability
The Dashboard's /opt/isr/configIsr.sh script has two options which allow you to configure Dashboard database HA. After starting the script, select the d option to add or modify the secondary Index host database configuration. Select the r option to delete the secondary Index host database configuration. For either option, follow the on-screen options when prompted.
