Field Parameters
The following list contains the currently supported Field parameters with a brief description of each. In addition, any defined Custom Data fields can be included as Field Parameters using the Custom Data field name in the template body (surrounded by percent % signs).
  • recordingId—recording ID
  • filename—audio recording filename
  • directory—audio recording file relative directory
  • isrUcid—ISR UCID
  • ingressCallId—ingress call ID
  • egressCallId—egress call ID
  • from—from/ANI
  • to—to/DNIS
  • accountId—account ID
  • routeId—route ID
  • rssId—RSS ID
  • agentId—agent ID
  • duration—duration (milliseconds)
  • durationSeconds—duration (seconds)
  • startDate—start date (yyyy-MM-dd)
  • startTime—start time (HH:mm:ss)
  • startDateUtc—start date in UTC (yyyy-MM-dd)
  • startTimeUtc—start time in UTC (HH:mm:ss)
  • startYear—start date year
  • startYearUtc—start date year in UTC
  • startMonth—start date month
  • startMonthUtc—start date month in UTC
  • startDay—start date day
  • startDayUtc—start date day in UTC
  • startHour—start time hour
  • startHourUtc—start time hour in UTC
  • startMinute—start time minute
  • startMinuteUtc—start time minute in UTC
  • startSecond—start time second
  • startSecondUtc—start time second in UTC
  • startMillisecond—start time millisecond
  • startMillisecondUtc—start time millisecond in UTC
  • startTimeZone—start time time zone (e.g. EDT)
  • startTimeZoneOffse— start time time zone offset (e.g. +0400)
  • pauseLength—pause length (milliseconds)
  • baseUrl base—URL (from which recording file is served)
  • sourceDirectory—archiver source directory
  • destinationDirectory—archiver destination directory
  • segmentId—segment ID
  • checksum—checksum (MD5)
  • endDate—end date (yyyy-MM-dd)
  • endTime—end time (HH:mm:ss)
  • endYear—end year date
  • endMonth—end month date
  • endDay—end date day
  • endHour—end time hour
  • endMinute—end time minute
  • endSecond—end time second
  • endMillisecond—end time millisecond
  • endTimeZone—end time zone (for example, EDT)
  • endTimeZoneOffset—end time zone offset (for example, +0400)
  • endDateUtc—end date in UTC (yyyy-MM-dd)
  • endTimeUtc—end time in UTC (HH:mm:ss)
  • endYearUtc—end date year in UTC
  • endMonthUtc—end date month in UTC
  • endDayUtc—end date day in UTC
  • endHourUtc—end time hour in UTC
  • endMinuteUtc—end time minute in UTC
  • endSecondUtc—end time second in UTC
  • endMillisecondUtc—end time millisecond in UTC
