VMware Enterprise vSphere Hypervisor (ESXi)
What is vSphere Hypervisor?
The vSphere Hypervisor (formerly known as ESXi), is the free edition of vSphere offering the bare-metal architecture for best possible performance. It installs during boot-time of the Hypervisor host.
The following components traditionally run on the Hypervisor platform:
- Index - MySQL Server stores the recording and management data
- Dashboard - Single ISR Dashboard for both the Administrator and User
- FACE API
Virtual Machine Default Resource Configurations
Any Hypervisor that Supports Oracle Linux Releases 7.2 - 7.6 are permitted. For more information, see the "Hardware" section of this guide.
A table on the VMWare Knowledge Base recommends certain VM virtual hardware versions (“VM Version” above) with Hypervisor (ESXi) platform versions. Although no misbehavior associated with the ISR hosts has been confirmed as related to hardware version incompatibilities, the latest virtual hardware version, vmx-10, has been successfully tested with the recommended Hypervisor version, VMware ESXi 5.5 Update 2. The following instructions from VMWare’s Knowledge Base explain upgrading the virtual hardware version of a VM:- Power on the VM to be upgraded.
- Install VMware Tools using vSphere client by right-clicking on the VM, selecting the Guest menu, and the Install/Upgrade VMWare Tools option.
- In vSphere client, right-click the entry for the VM and select Upgrade Virtual Hardware.
- In vSphere Client’s General Summary of the VM confirm the VM Version value is vmx-10.
- Power on the VM.
